2000V70SLEEPER Posted August 4, 2011 Report Share Posted August 4, 2011 WOW THROTTLE BODY 1st ,THEN O2 SENSOR 2nd; AND NOW ALTERNATOR PROBLEMS ! CAN I CHANGE ALTERNATOR WITHOUT DEALERS HELP CORRECTLY. PLEASE HELP... Link to comment Share on other sites More sharing options...
Dan A Posted August 12, 2011 Report Share Posted August 12, 2011 1. Your car is 11+ years old. 2. You need to take caps lock off and post in the right forum. 3. I have no idea if you can do this correctly. If you have a specific question on the install then maybe someone will help. Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 12, 2011 Report Share Posted August 12, 2011 WOW THROTTLE BODY 1st ,THEN O2 SENSOR 2nd; AND NOW ALTERNATOR PROBLEMS ! CAN I CHANGE ALTERNATOR WITHOUT DEALERS HELP CORRECTLY. PLEASE HELP... And before you answer the question: "Can I do it ?", Are you SURE the alternator is bad? Link to comment Share on other sites More sharing options...
slowvo Posted September 18, 2011 Report Share Posted September 18, 2011 I just had my alternator replaced. Make sure you check your battery cables (especially the positive) and also the positive power feed cable (I think it is called a B cable) connected inside the fuse box. Make sure the connections are tight and if the one inside the fuse box is black or burned, it probably needs replacement. I'm not saying these ARE the problems but they could be as they can cause some problems in voltage. Link to comment Share on other sites More sharing options...
