(_8*(l)Homer Posted August 14, 2011 Report Share Posted August 14, 2011 results? Link to comment Share on other sites More sharing options...
rbodor3 Posted August 14, 2011 Author Report Share Posted August 14, 2011 well I was looking up this on Vida and can't find it, but I can find removing the subframe which is a huge pain. There must be an easier way to do this than removing the entire subframe. Link to comment Share on other sites More sharing options...
MrWinkey Posted August 14, 2011 Report Share Posted August 14, 2011 Just remove the rear bolts and slightly loosen the front ones if needed..pry down and pop them on top of the rear bushings....CAREFULLY !! Link to comment Share on other sites More sharing options...
rbodor3 Posted September 4, 2011 Author Report Share Posted September 4, 2011 installed o-rings. Still pops loudly from any accel from a stop, or left turn. any other ideas?? Link to comment Share on other sites More sharing options...
Tommy. Posted September 4, 2011 Report Share Posted September 4, 2011 Nobody said it yet. How do your axles look? Link to comment Share on other sites More sharing options...
rbodor3 Posted September 4, 2011 Author Report Share Posted September 4, 2011 axles good, just rebuilt them and checked them while under there for installing the o-rings. Should I have gotten O-Rings to install in the front bushings too? I only did rears. Link to comment Share on other sites More sharing options...
rbodor3 Posted September 5, 2011 Author Report Share Posted September 5, 2011 I wonder if this is normal: when I lift the car and support from the subframe, I can wiggle each front tire about 1/4" in either direction. I think the actual steering column moves. My tie rods (inner and outer) are brand new (literally, saturday) because I did have some play beforehand. Is this normal? Possibly cause? Link to comment Share on other sites More sharing options...
rbodor3 Posted September 7, 2011 Author Report Share Posted September 7, 2011 bump. Can anybody verify when both tires are lifted off the ground, how much play is at the front wheels through the steering column? I have a little bit of wiggle, but I tihnk the actual steering wheel moves. I have brand new tie rods, literally last weekend. Snugged. Control arm bushings = good, ball joints = good, springs = good, seats= good, shocks = good, axles = good, tires = new, alignment = good. Soooo, only thing I could magine is steering rack replacement??!? Link to comment Share on other sites More sharing options...
rbodor3 Posted September 18, 2011 Author Report Share Posted September 18, 2011 turned out to be driver's ball joint. I checked it a couple of times, no boot tearing so I figured it was fine. And with the car in the air, the droop pushed the joint hard against the control arm so I couldn't tell the ball joint was so worne. When I did get the ball joint off, it was terribly worne. I'll post a video of it (I left my camera at the bars) Link to comment Share on other sites More sharing options...
pcguru000 Posted September 19, 2011 Report Share Posted September 19, 2011 Looks like you figured it, good work I was going to suggest (for reference if anyone else is ever hunting this issue) - in my 850 after installing new springs i had a similar popping sound... turned out to be a spring upside down - the mechanic who did the job was a bit embarrassed but claimed he thought could go in either way. Link to comment Share on other sites More sharing options...
Milo Posted September 20, 2011 Report Share Posted September 20, 2011 Sorry I didn't look at this earlier as it is very much a balljoint/control arm sounding issue. Easy test of that is as you did, put the car up and try to move the wheel back and forth. Good that you fixed it, that's a quick way to ruin some tires. That is a whole control arm and ball joint assembly right? I know the 94 850 was a two piece unit but after that it was one unit. I don't know about the S60 though. Link to comment Share on other sites More sharing options...
rbodor3 Posted September 21, 2011 Author Report Share Posted September 21, 2011 I did lift and wiggle the tire, back and forth & up/down. Couldn't repeat the noise, because the balljoint was worn in such a way that when the suspension was at droop enough force was against the control arm to keep the ball joint seated! It really only would pop out of place. The CA on the S60 is separate from the ball joint. Ball joint is press-fit and then has (2) capscrews holding it into the bearing housing. Was sort of a PITA to remove Link to comment Share on other sites More sharing options...
Gilhuly Posted September 30, 2011 Report Share Posted September 30, 2011 I also would suspect an axle. You are lowered so have less than ideal geometrySorry about that, I didn't notice page 2. Link to comment Share on other sites More sharing options...
FCP Euro Posted October 9, 2011 Report Share Posted October 9, 2011 Do you get this same pop shifting from drive to reverse and vice versa? Link to comment Share on other sites More sharing options...
