volvoluvin Posted August 24, 2011 Report Share Posted August 24, 2011 Tonight, I pulled hard off the line, chirp, revs, 30kms, 5000rpm, full boost, suddenly, rev limiter, wtf, shift, go no where...car running...no smoke...no oil, no exploding pieces flying... I can make the speedo move by putting it in gear and reving...but car doesn't move...nasty noises occur if I put it in 5th and rev the motor... What did I explode? Quaffie diff? Output shaft? Worse? Any thoughts/help would be useful... Link to comment Share on other sites More sharing options...
tca217 Posted August 24, 2011 Report Share Posted August 24, 2011 Axels? Put it on jack stands, have someone put it in gear and let out the clutch slowly and look underneath at the axels and see if they are moving or not. Someplace to start anyhow. Good luck.......................TIM Link to comment Share on other sites More sharing options...
Dick Dastardly Posted August 24, 2011 Report Share Posted August 24, 2011 This doesn't sound good..Its acts like its in neutral when in gear, just noisy?.. I would check for broken axle or CV joint first too...maybe splines on shaft or hub too..(I have had that happen before on another car)..after that..UH OH Do what tca217 suggested and safely jack it up and run it in gear and see what, if anything, is turning... Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted August 24, 2011 Report Share Posted August 24, 2011 if you broke an axle the other wheel won't turn. i forget if the speedo acted like that when my axle snapped. Link to comment Share on other sites More sharing options...
TRACStar Posted August 24, 2011 Report Share Posted August 24, 2011 I'm not sure how the diff is setup but I would think it must be something in the diff/axles since the speedo registers movement. Where does the speedo pickup its signal from? If it was a factory open diff and the axles were ok if say you fragged the spider gears. How long had the diff been in? Maybe there was a factory defect. Dismiss everything I said about the diff if you check it and find a broken axle. :lol: Link to comment Share on other sites More sharing options...
TyConn Posted August 24, 2011 Report Share Posted August 24, 2011 abs module calculates the speed...ever notice if you disconnect both of the front abs sensors, you don't have a speed reading? Link to comment Share on other sites More sharing options...
volvoluvin Posted August 24, 2011 Author Report Share Posted August 24, 2011 Thanks gents - I'll know more end of day - Considering I'm running a Quaife LSD in it, I'm REALLY hoping I didn't bone that... I've also been having some weird driveline "tramping" on throttle lift, so I'm wondering if that has something to do with it... This will suck if it's a big explosion of internals... Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 24, 2011 Report Share Posted August 24, 2011 abs module calculates the speed...ever notice if you disconnect both of the front abs sensors, you don't have a speed reading? Different speedo input here - He's driving a '95. Link to comment Share on other sites More sharing options...
ozzimark Posted August 24, 2011 Report Share Posted August 24, 2011 What did I explode? You'll find out really quick when you look under the car. :P Link to comment Share on other sites More sharing options...
BlackT5 Posted August 24, 2011 Report Share Posted August 24, 2011 The older models have the speed gear on the diff, so your diff is spinning if the speedo goes up. Jack it up and take a look, probably an axle. Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 24, 2011 Report Share Posted August 24, 2011 If there's a Quaife in there, I sure Hope it's an axle! Link to comment Share on other sites More sharing options...
volvoluvin Posted August 24, 2011 Author Report Share Posted August 24, 2011 It was the clutch - I had it towed to a shop as I don't have the time right now...Not sure what part of the clutch, don't have those details yet...fun... Link to comment Share on other sites More sharing options...
Volvo5.0 Posted August 25, 2011 Report Share Posted August 25, 2011 I can make the speedo move by putting it in gear and reving...but car doesn't move... It was the clutch - I had it towed to a shop as I don't have the time right now...Not sure what part of the clutch, don't have those details yet...fun... If the clutch is slipping bad enough that the car won't move, then the speedo shouldn't move. Hate to see you buy a clutch if it's something as simple as an axle :o Link to comment Share on other sites More sharing options...
volvoluvin Posted August 25, 2011 Author Report Share Posted August 25, 2011 If the clutch is slipping bad enough that the car won't move, then the speedo shouldn't move. Hate to see you buy a clutch if it's something as simple as an axle Ya - I'm just not 100% convinced either...I just can't see how it's the clutch...this was a case of full let go...no "partial" grabbing etc...just nothing... Rev the car in any gear and you would see the "appropriate" speed for that gear/rpm on the speedo...but it no go...there was some metalic sounds in 5th at 100kmh when sitting there... I'll go out and see it next week and get better details...I'm away for a few days... Either way, it's out of action for a while... Link to comment Share on other sites More sharing options...
TRACStar Posted August 25, 2011 Report Share Posted August 25, 2011 If the clutch is slipping bad enough that the car won't move, then the speedo shouldn't move. Hate to see you buy a clutch if it's something as simple as an axle This. If the speed is picked up off the diff and the speedo registers speed than it has to be something post diff. My brain refuses to let me think anything else. Unless there is something REALLY weird going on. If its picked up off the abs then someone stole your wheels. If a shop is telling you this try to have someone else (that you trust) check it out. Volvo5.0 is absolutely right, if your clutch wasn't catching at all, nothing in the trans would turn= no speedo movement. Link to comment Share on other sites More sharing options...
