volvo940tuner Posted September 6, 2011 Report Share Posted September 6, 2011 Had this weird boost problem for a while. This is all with an Upsolute 17 PSI tune, and the stock 15g. When I would originally go full throttle, it would boost, just seemed to not be enough boost. Hooked up a boost gauge finally, and it was only making about 7 psi under full throttle..and was bouncing back down to 4-5, then back to 7. Hooked up an S70 BCS..same problem, although it would boost to about 10 psi, then down to 6-7, then back to 10. Installed a manual boost controller..and now the boost no longer bounces around..but if I was to go full throttle, the car would surely overboost and throw a rod. No matter which way I turn the MBC, it doesn't turn the boost up or down. The boost IS consistent now and no longer bounces around..but even at 3/4 throttle I can make 18 psi. Think the wastegate needs to be adjusted?? Link to comment Share on other sites More sharing options...
greekone Posted September 6, 2011 Report Share Posted September 6, 2011 Yes, adjust the wastegate. Link to comment Share on other sites More sharing options...
*Officine Panerai* Posted September 6, 2011 Report Share Posted September 6, 2011 yup, hook the bcs back up and adjust your wastegate until you hit proper psi. Link to comment Share on other sites More sharing options...
volvo940tuner Posted September 6, 2011 Author Report Share Posted September 6, 2011 Sounds good. As a side question..how much of a PITA is it to change out the turbine housing? I bought an OBX exhaust, and I am switching the turbine housing to an angled type. Link to comment Share on other sites More sharing options...
volvo940tuner Posted September 6, 2011 Author Report Share Posted September 6, 2011 I guess I will just start spraying PB all over the studs in prep for this. Thanks for the info. Link to comment Share on other sites More sharing options...
*Officine Panerai* Posted September 6, 2011 Report Share Posted September 6, 2011 its not a complete PITA but is certainly harder than changing the air filter Link to comment Share on other sites More sharing options...
greekone Posted September 6, 2011 Report Share Posted September 6, 2011 Not too hard, there's a v-band clamp holding the housing on. Link to comment Share on other sites More sharing options...
