The "other" Awd Failure - Dem Stuff
NJGreenBudd
  • Replies 57
Thanks a bunch! I am starting my investigation of my non-functioning AWD. I don't want to hijack the thread, but curious to know if NJGreenBud (or others) can offer
advice on the following codes that were pulled a few weeks back.
- BCM-0094 (note - in the details, it says pump engine, status "not active". Does this mean the haldex pump is kaput?). I don't understand what this frozen value field means.
-BCM-0100, 0115
- ECM-510F, 928C, 9400
Note -there were DDM, PDM's as well, but this is related to windows and mirrors (that much I figured out).
From the BCM and ECM's, it seems that the starting points should be:
-check DEM sensor / connector
-AOC (connector, grounds, check the oil, clean up the sensor....maybe replace it with the oil while we have it opened?)
-check CAN cable
Thanks! This advice helped a little bit, but the connectors were incredibly brittle, and suffered some damage (see pics attached). I tested to see if they still "connect" and they do.
Perhaps a bit of electrical tape or a hose clamp?
post-42824-0-76758600-1329866223_thumb.jpost-42824-0-65657200-1329866224_thumb.jpost-42824-0-50433400-1329866225_thumb.jpost-42824-0-39342300-1329866226_thumb.j
The unit wasn't super "dirty" on the backside, but from my chats with Xemodex (amazing tech help) the codes seemed to relate to a bad DEM. Now that winter's here, I need AWD again (especially on the Canadian prairies).
DEM back from Xemodex (within 1 day). The Xemodex tech mentioned "be careful' with the washer. I was told "it can only really only go on one way", but I am still perplexed. I did read the VADIS instructions regarding the washer "convex side against the temp / pressure sensor." I assume this is when you take the sensor out (something I didn't do).
Anyone want to chime in, which way do I put the washer in prior to the DEM going back on? I will repay in one virtual cold canadian barley beverage!
