FAST850R Posted September 24, 2011 Report Share Posted September 24, 2011 Hello, I was going to replace trunk struts, but I don't know how. It seems like I don't need any wrench, sockets....but I am not sure. Can anyone give me advice how to replace them? Thank you. Link to comment Share on other sites More sharing options...
marcopolo Posted September 24, 2011 Report Share Posted September 24, 2011 Wagon or sedan? Link to comment Share on other sites More sharing options...
Guest hotfoot Posted September 25, 2011 Report Share Posted September 25, 2011 He said "trunk", so I assume he's crawling around inside his sedan...On my 850R, the entire panel that goes from the rear seat, along the side, back to the trunk lid has to be popped off for access. I use a pair of those really long Harbor Freight "pinch-type" longnose pliers to get behind the panel and pop the plastic screws out nicely, without breakage...have been using those for years on a variety of vehicles, and have saved countless plastic gizmos from breakage (still have ruined a few). I still haven't gotten to my struts, and having the Timing Belt .Water Pump done in a couple days, then the trunk struts will follow. It seems there are two types, depending is there is a spoiler or not, so be sure to get the proper ones. Link to comment Share on other sites More sharing options...
trs80 Posted September 25, 2011 Report Share Posted September 25, 2011 The end of the strut that connects to the trunk is pressed onto a post and retained by a small clip. The body end is a U shaped connection that is pressed down and into place. So in order to remove them, first locate the retaining clip and remove it. Set aside as it will be reused. Then simply pry the strut off the small post, make sure the plastic bushing comes off as well. Next hit up on the strut till it pops off the other end. The install is simply reverse. Do this with the trunk closed or securely propped open, it is extremely heavy and will hurt if taken to the face. I attached both replacements to the body first and then had a helper hold the trunk open so I could press the other end onto the small posts. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted September 25, 2011 Report Share Posted September 25, 2011 Sedan: http://volvospeed.com/volvo_repairs_how_tos/doors_latches/trunk_strut_replacement.html Wagon: http://volvospeed.com/volvo_repairs_how_tos/volvo_trim_parts/855_v70_tailgate_strut_replacement.html Link to comment Share on other sites More sharing options...
FAST850R Posted September 25, 2011 Author Report Share Posted September 25, 2011 The trunk is already heavy and the struts are not holding it anymore. Thank you so much for the links and advice. It's time to fix them. Link to comment Share on other sites More sharing options...
Kayci Posted September 27, 2011 Report Share Posted September 27, 2011 If yours happens to be a wagon, I found it easier to loosen the 2 bolts holding the bracket attached to the body; provided more wiggle room and the strut came out easily with a few knocks of a hammer. The trunk end came out with ease just prying it with my hands. Link to comment Share on other sites More sharing options...
FAST850R Posted September 28, 2011 Author Report Share Posted September 28, 2011 Thank you for the tip, Kayci. Mine is a sedan so it's little different. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted September 28, 2011 Report Share Posted September 28, 2011 I used a pry bar to pop them off Link to comment Share on other sites More sharing options...
