04S602.5T Posted September 26, 2011 Report Share Posted September 26, 2011 My turn signal switch is going bad, looks like a simple fix. I did read up on few blogs that mention that there will be 2 hex screw and it should come out, but when i took of the rubber protector did not see any screw. Should I just yank it out or do I have to take to the dealer? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted September 26, 2011 Report Share Posted September 26, 2011 You need to remove the torx T25 screws that hold the steering column cover on, after that you'll be able to access the two phillips head screws that secure the stalk. Link to comment Share on other sites More sharing options...
04S602.5T Posted September 26, 2011 Author Report Share Posted September 26, 2011 yes where is this T25 located? After spending 15 min have located any T25.have not located any T25 Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted September 26, 2011 Report Share Posted September 26, 2011 the screws are located in the lower column cover, 3 T25's. They sit recessed in the cover, seperate the halfs and it'll be self explanitory. Link to comment Share on other sites More sharing options...
