highhighs Posted January 11, 2005 Report Share Posted January 11, 2005 hi all,i noticed today that all the wires from my antenna are disconnected(cut) back in the trunk (meaning 10cm of wire dangling from antenna motor) can somebody plz give me the wire colors i should connect them to and anyother wires that look similar and i should not touch. all 4 wires are disconnected(behind the driver side stop light)thank you Link to comment Share on other sites More sharing options...
Figawi Posted January 11, 2005 Report Share Posted January 11, 2005 can you see the other end of the wires that were cut? if so, just connect those up according to color match. Link to comment Share on other sites More sharing options...
highhighs Posted January 11, 2005 Author Report Share Posted January 11, 2005 this is the problem: there appear no wires that are loose that i can connect the antenna wires to :blink: Link to comment Share on other sites More sharing options...
theunderlord Posted January 11, 2005 Report Share Posted January 11, 2005 this is the problem: there appear no wires that are loose that i can connect the antenna wires to ←does your radio reception still work well? Link to comment Share on other sites More sharing options...
highhighs Posted January 11, 2005 Author Report Share Posted January 11, 2005 the signal wire is connected(black think one) and the antenna is stuck at half open. and yes the signal is good most of the time but some kids broke the ip of the anenna that why i want it to retrackt Link to comment Share on other sites More sharing options...
Mesoam Posted January 11, 2005 Report Share Posted January 11, 2005 hmmm...Well coming off the HU the antenna is the Blue/White wire, i would guess that wire traveled back to the antenna :unsure: Link to comment Share on other sites More sharing options...
PyROZen Posted January 11, 2005 Report Share Posted January 11, 2005 there should be a wiring harness you can plug into. I know when i got my 850 the antenna was disconnected too, i pulled the mast out and re-fed it into the housing. If you don't see a wiring harness then you will have to re-wire. Link to comment Share on other sites More sharing options...
highhighs Posted January 11, 2005 Author Report Share Posted January 11, 2005 no harness to connect to and there appears no loose wires in the wire bundle to connect the antenna wires to thank you Link to comment Share on other sites More sharing options...
Patrick. Posted January 12, 2005 Report Share Posted January 12, 2005 why anyone would cut those wires is beyond me Link to comment Share on other sites More sharing options...
Veneficus Posted January 12, 2005 Report Share Posted January 12, 2005 why anyone would cut those wires is beyond me←Because the antenna is verrrrrrry annoying and if you use a tape deck, why would you need the antenna? Link to comment Share on other sites More sharing options...
