theunderlord Posted January 11, 2005 Report Share Posted January 11, 2005 Say you got a used turbo. What woud you do to it before you put it on your car? Link to comment Share on other sites More sharing options...
swdracr Posted January 11, 2005 Report Share Posted January 11, 2005 Remove the old one. If it seems like it's worn out you could send it somewhere and have it rebuilt.. but then again if it's spent you probably wouldn't have bought it in the first place. How are the blades? Shaft play? Link to comment Share on other sites More sharing options...
theunderlord Posted January 11, 2005 Author Report Share Posted January 11, 2005 How are the blades? Shaft play?←I'm not sure about the 13G.. but the new (used one) : Zero shaft play....well... not very much... blades are a bit dirty, look sharp, (no dings or anything) Link to comment Share on other sites More sharing options...
TorqueSteer Posted January 11, 2005 Report Share Posted January 11, 2005 I would dremel out the exaust housing extrance a bit. Link to comment Share on other sites More sharing options...
theunderlord Posted January 11, 2005 Author Report Share Posted January 11, 2005 anyone got any decent pics of a 16T vs a 18T ? I know Mark (850ridah) has one.. the turbo i just got doesn't have a nameplate on it.. is there any way to be sure which one it is? Link to comment Share on other sites More sharing options...
StickThatClutch Posted January 11, 2005 Report Share Posted January 11, 2005 Does it have a serial number? Link to comment Share on other sites More sharing options...
theunderlord Posted January 11, 2005 Author Report Share Posted January 11, 2005 Does it have a serial number?←where would I find that? there are quite a few number on it.. I know the part number should be 9454563... but I think that just goes on the nameplate... Link to comment Share on other sites More sharing options...
StickThatClutch Posted January 11, 2005 Report Share Posted January 11, 2005 You know what its probably on the nameplate as well. You can look up the turbo model via the serial. In your case it looks like your out of luck.I think there are some critical diameters you can measure to compare the different model turbos in the same housing. I'm no expert on this so I can't offer you any further advice. Good luck. Link to comment Share on other sites More sharing options...
S70 R Posted January 11, 2005 Report Share Posted January 11, 2005 ha ha no 18 t for kevin Link to comment Share on other sites More sharing options...
theunderlord Posted January 11, 2005 Author Report Share Posted January 11, 2005 ha ha no 18 t for kevin←well even if it isn't the price was right, and if it's a 16T is still a huge improvement over my 13G... anyone know the dimensions on the 18T? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted January 11, 2005 Report Share Posted January 11, 2005 probably has a 3" exhaust outlet flange like the 19T's instead of the 15g and 16T 2.5" Link to comment Share on other sites More sharing options...
theunderlord Posted January 11, 2005 Author Report Share Posted January 11, 2005 probably has a 3" exhaust outlet flange like the 19T's instead of the 15g and 16T 2.5"←whaddya think Joseph? Link to comment Share on other sites More sharing options...
Overboost850 Posted January 11, 2005 Report Share Posted January 11, 2005 16T Link to comment Share on other sites More sharing options...
StickThatClutch Posted January 11, 2005 Report Share Posted January 11, 2005 Kevin said the ID of the exhuast is 2.35" that doesn't match up with the ID of the 16t which should be 2.2" its more on lines of the 19t. So good money on it NOT being a 16t.EDIT: thoughts that it could have been altered before coming into Kevin's possession could skew normal dimension data. Link to comment Share on other sites More sharing options...
StickThatClutch Posted January 11, 2005 Report Share Posted January 11, 2005 More info can be found here.http://www.stealth316.com/2-turboguide.htm Link to comment Share on other sites More sharing options...
