Name This Turbo!
  • Replies 56
Why would you opt 18T over 19T?
Just curious. 18T is pretty hard to find. 19T's flow better and are more common.
Good luck.
Edit: Grammar (its still probably wrong)
a big reason that i wood opt for an 18t is the the strait flange....
..but does that change the angle of the outlet / throughlet to the down pipe? does that influence the flow (rate) of the exhaust gases?
a. ----I----- or b. -----/-------
flow should be -----------------> either ways. Or am i totally wrong?
thats a long wait :(
but I bet it'll be worth it  :D
(only problem then is that you have pretty much modded-out your car.............but there's always the engine left ;) )
....and is still have the b5234t3 ('98) with 80K km on it. and go the verdi rod, oem overbore piston way, perhaps? plus some porting+polishing? :)
my guys checkin on it again, but he swears up and down (and he really has no reason to lie about it) that it came out of a 1998 S70R. which is the 18T.. so we're hopin! :)
It measured 1.8 inch inlet which is roughly 46 mm.
A 19T measures ~47 mm and a new style 16T near 44 mm inlet.
Just thought i would add:
manual s70r's come with the 18t and the auto's with 16t's.
if someone can post a pic of the compressor wheel from the 18t and 16t next to a 15g then i might be able to help as i remmeber looking at the wheel before i installed my 18t onto a 15g 850r. and they were clearly very different.
