850rclone Posted October 29, 2011 Report Share Posted October 29, 2011 Ok so this may sound nebbish but it's not. Bought this car about a year ago and test driving it it didn't have much power something was wrong. So took it back to the shop and figured out one of the one-way check valves went bad. Replaced that. Pretty quick car now. So then I started hearing a "whistle" when the turbo is spooling. It happened at 1 lb and continues all the way till you let off the gas. So again went back to the shop and hooked up the intake leak pressure tester and did a smoke test. And nothing came out bad. I replaced all the vacuum lines and made sure everything was tight and up to date. Then i saw the intake was missing a few bolts. Put a new intake gasket on( and new flame trap system while the intake was off) still made the spooling noise. I have never had a turbo go bad on me and it doesn't sound like the turbo's i have heard that are bad. I turned the boost up to 14 psi (well kinda. I counted 14 turns and supposed to be about 1 psi/ turn) and the boost gauge read 8. So that makes me think an intake leak but no smoke appears or anything. Thoughts anyone? Link to comment Share on other sites More sharing options...
550 Posted October 29, 2011 Report Share Posted October 29, 2011 14 turns ~ 14 psi. There are things that will affect that. Whats your wastegate preload at? Link to comment Share on other sites More sharing options...
850rclone Posted October 29, 2011 Author Report Share Posted October 29, 2011 I havent touched it yet. I didn't even think that a hundred percent through :( Link to comment Share on other sites More sharing options...
realbad780 Posted October 29, 2011 Report Share Posted October 29, 2011 Sounds like CBV to me, I just replaced mine with the IPD HD cbv and its holding boost again. Link to comment Share on other sites More sharing options...
850rclone Posted October 30, 2011 Author Report Share Posted October 30, 2011 Ok, ill look into that! Thanks ill let you know if it fixes it. Link to comment Share on other sites More sharing options...
