jroot Posted October 29, 2011 Report Share Posted October 29, 2011 I've read many posts saying that the 302mm brake upgrade won't rub with perfos but I'm experiencing rubbing. I haven't been able to check to see exactly what's rubbing (bracket or rotor) since it's raining but will do so hopefully tomorrow. Has anyone else had this problem with perfos? Am I missing something? It does sort of sound like it's only coming from the driver side but that could be because I'm sitting on the driver side so I hear it more. Thanks Jay Link to comment Share on other sites More sharing options...
Mesoam Posted October 29, 2011 Report Share Posted October 29, 2011 i know you've been a member here for a while but are you sure you have perfo's and not columbas Link to comment Share on other sites More sharing options...
jroot Posted October 29, 2011 Author Report Share Posted October 29, 2011 Yeah. I have a s70 t5 that came with the perfos kind of why I'm puzzled but who knows maybe something came lose while switching to my winter wheels. Correct me if I'm wrong but the Columbas were what came on the 94-97 850 Turbos. Link to comment Share on other sites More sharing options...
gotboost Posted October 29, 2011 Report Share Posted October 29, 2011 Post a pic of your wheels. My '98 S70 T5 SE came stock with Anthracite Columbas which will not work with the 302mm brakes. I know people are probably going to say that S70's never came with Columbas, but I have the original window sticker to prove that a few did. Is your car by chance an SE model? Link to comment Share on other sites More sharing options...
gmsgltr Posted October 29, 2011 Report Share Posted October 29, 2011 edit: nvm Link to comment Share on other sites More sharing options...
854TGA+ Posted October 29, 2011 Report Share Posted October 29, 2011 I'm running 302's with Columbas. Very slight grind was required to caliper bodies and wheel weights have to be mounted behind wheel spokes ;) Link to comment Share on other sites More sharing options...
jroot Posted October 29, 2011 Author Report Share Posted October 29, 2011 Post a pic of your wheels. My '98 S70 T5 SE came stock with Anthracite Columbas which will not work with the 302mm brakes. I know people are probably going to say that S70's never came with Columbas, but I have the original window sticker to prove that a few did. Is your car by chance an SE model? I'm positive they are perfos. They look like these: http://www.dealershipaccessories.com/stores/images/items/item_40742.gif Link to comment Share on other sites More sharing options...
gotboost Posted October 29, 2011 Report Share Posted October 29, 2011 I'm positive they are perfos. They look like these: http://www.dealershi.../item_40742.gif Hmmm...those are definitely perfos. Maybe you bent the dust shield a little bit when installing everything??? I did that when doing a brake job on my XC one time and it was rubbing on the brake rotor. Just a thought. Link to comment Share on other sites More sharing options...
jroot Posted October 29, 2011 Author Report Share Posted October 29, 2011 Hmmm...those are definitely perfos. Maybe you bent the dust shield a little bit when installing everything??? I did that when doing a brake job on my XC one time and it was rubbing on the brake rotor. Just a thought. Yeah I'll have a look tomorrow to see what's going on...but just figured I'd ask to see if anyone else experienced something similar with perfos but I had doubts that anyone has. Link to comment Share on other sites More sharing options...
Mesoam Posted October 29, 2011 Report Share Posted October 29, 2011 an even slightly tweaked dust shield can make for some serious noise maybe FIORE can comment on that :lol: Link to comment Share on other sites More sharing options...
crazykn Posted October 30, 2011 Report Share Posted October 30, 2011 I experienced a weird problem after installing the new upgrade caliper bracket. Because they painted on glaze to shine up the refurbished bracket (they refurbish cores), I couldn't put in the pads because the glaze is keep it from fitting that one last milimeter or so. So because I was rushed for time, I took the dremel and sanded off the edges of the pad metal side backing, to make it fit. The pads are from Centric brakes and I checked them with the OEM, and they are the correct size. I should've sanded off the glazed part of the caliper bracket instead. Time to fix it. Link to comment Share on other sites More sharing options...
Jeigh Posted October 30, 2011 Report Share Posted October 30, 2011 I ran 302mm uprgrade with perfos. where did you purchase your brake components? Link to comment Share on other sites More sharing options...
jroot Posted October 30, 2011 Author Report Share Posted October 30, 2011 I ran 302mm uprgrade with perfos. where did you purchase your brake components? I purchased the brackets from Volvo and the rotors + pads from FCP. Link to comment Share on other sites More sharing options...
Jeigh Posted October 30, 2011 Report Share Posted October 30, 2011 is it rubbing on both sides? Link to comment Share on other sites More sharing options...
jroot Posted October 31, 2011 Author Report Share Posted October 31, 2011 is it rubbing on both sides? Nope. Turned out to be the dust shield...damn thing :) Link to comment Share on other sites More sharing options...
