Project: 1998 Olive Green T5 Manual V70
Ghost Shadow
  • Replies 110
How much does the whole keyless/alarm setup run $$ wise?
retails For just the Remote start/Alarm Paging @ $699, Drone $349, Touch Rps $69
What i would sell these for on any given day? $950 plus transponder interface if you needed it $25-99 bucks.
In another 93-97 850 or 98-00 x70 $700
i am serious i know someone who is in the market if you sell...
I have now racked up 150 miles since the engine is complete.
Only a few problems left
  • need another 350 300 275 235 miles before i can open her up :P
  • squeak in the rear found that last night, loose panel
  • Whining noise when i get to 30mph stupid load bars whining like a bitch...weeeeee weeeeeeeee, now its ohh so quiet
  • waiting to be installed FMIC, in the garage
  • waiting to be installed blocking plate
  • Ordered/payment sent OBX straight flange down pipe
  • waiting to be installed Magnaflow Muffler to replace suit case
  • ordering a high flow cat
  • waiting to be installed Motorola IHF1000 with a mss switcher
  • look into oil cooler
  • not ordered yet, New front rotors, old ones warped
  • not ordered yet, New rear rotors, might as well since...
  • waiting to be done, New parking brake cable
  • waiting to be done, New OEM trans fluid
  • waiting for it to tear, they cracker, passenger side axle boots
  • looking for, New ABM projectors or used ones
Basically mods LOL, Greg...Its going to be hard to part with it. It truly is a amazing vehicle at 155050 miles. You would not believe it, i dont believe it when i drive it.
Just alaigned it yesterday and my trusty friend there said, "Steve, i like all you other cars, but now this is my kind of car. Stock suspension, quiet, regular wheels, manual transmission, no irregular noises, starts right up, and its clean inside/outside/underside..Id be interested if you wanted to sell it." told him i was going to enjoy it for a little while longer. I told him i got rid of my last toy too soon, referencing the btcc replica. :(
I will entertain offers as i progress with it. You and your friend should get together and come over one day and check it out. If they really like it make me a offer and we can go from there. I honestly dont need 3 volvos + 1 more to fix in the driveway.
PM me we can set something up.
Hottttt.... I like this car a lot. :) So i guess with the remote start you have to remember to park it in neutral huh?
thanks.
Nope, doesnt matter!!
You need to satisfy 3 criteria in order for a successful restart remotely
  1. parking brake needs to be engaged
  2. when key is removed, car will stay running
  3. exit vehicle and car will remotely set and wait
  4. for you to arm/activate and lock the car
  5. car is secure, ready to be restarted
This means
  1. car will not roll away since brake is on
  2. car was in neutral since you got out of the car and it was running
  3. since you got out of the car, brake was on and it was running. system was secure
  4. you armed and lock the doors
Now if you disarm go in and get your wallet and get out and re arm it. it will not start, you just compromised the car. you may have inadvertently hit the car into gear. thus if you tried it will give you a reservation mode not set error. so you have to go thru the setup procedure all over again. yes is it a pain? yes. is it safe? yes. can you get it to start in gear? yes, but thats trying to defeat it. Is there anything else out there that does the same thing besides compustar? not that i know of and with all the same safetly features.
Despite the oil spill, you still used Valvoline, right?
Those Castrol bottles scared me for a while.
had do use up all the loose odds and ends i had. used .5 more castol, 2 valvoline, and 1.5 royal purple(arrg) its all only for 500 miles. that went from a $20 on sale valvoline $20 for filter and 5.23quarts to $60 oil change job! ARRG
parking brake shoes were so bad, i thought they needed new cables. one side the shoes were totally gone the other side was coming off...now it just needs two clicks to lock em in tite.
OEM shoes, up next new axles/rebuilt
  • ordering ordered a magnaflow high flow cat
  • waiting to be installed Motorola IHF1000 with a mss switcher done
  • look into oil cooler leaking @ radiator idiots never tightened it down
  • waiting to be done, New parking brake cable not broken, was bad parking brake shoes
  • waiting it broke, they cracked, passenger side axle boots, getting new ones today
  • looking for, New ABM projectors or used ones click BIN on ebay from autolamps plus in florida
Who ever thought of the drop the control arm off the frame method for removing the axle should get a medal! I personally never did it that way, why i dont know.
Today tried to remove the ball joint and after 15 minutes gave up, remembered that someone said to remove subframe bolts. that made the job all of 15 minutes per side.
Olive green got today:
  • TwoNew Rebuilt Axles
  • New Bosch Fuel Filter
  • New Volvo 75w80 transmission fluid 2 1/4 containers worth. thats $60 in Volvo fluids! WTF shits expensive
tomorrow she might get a new exhaust system.
Why new axles?
They dry rotted out :/
Update:
No drone, magnaflow set up is as follows
OBX straight flange $135
Magnaflow 3" Hi Flow Cat 94109 $99
Magnaflow 14326 replaced the "suitcase" $125
2 hangers, 1 O2 Sensor bung $5
Labor $85
Done.
1st gear mashing throttle
reving at idle
behind the car at idle, video is louder than it actually is
Bleeding brakes properly requires something like the Motive power bleeder. It's totally straightforward.
But you don't have to bleed them in order to replace pads.
