Brad850 Posted November 1, 2011 Report Share Posted November 1, 2011 When I accelerate at 40 mph I can feel a light vibration in the gas pedal and only the gas pedal. It usually only happens when I give it maybe a little more than half throttle. Most of the time when the car downshifts and I stomp on it, or If i just stomp on it in general I get no vibration. No sound associated with it so i assume it's not detonation or anything of that nature? Happened before and after I did stage zero. Plugs are gapped .026 and I recently installed an msd Any ideas? Link to comment Share on other sites More sharing options...
850R Hooligan Posted November 1, 2011 Report Share Posted November 1, 2011 I experienced something similar and it turned out to be a broken throttle cable. Where the cable penetrates the firewall there is a rubber boot and plastic clip that is a pressure fitting. Check there to see if the cable/boot/clip has broken allowing the cable to flop around. That boot/mechanism should be snug against the firewall. If it is that i got a new cable from the dealership for $61.00 and it took about 15 mins to install. Link to comment Share on other sites More sharing options...
Brad850 Posted November 2, 2011 Author Report Share Posted November 2, 2011 Is any part of the boot thats coming out of the firewall meant to move at all? I can twist and wiggle it a bit. Link to comment Share on other sites More sharing options...
