FAST850R Posted November 1, 2011 Report Share Posted November 1, 2011 I have 1996 850, and one of the mud flaps is just hanging. I need to re install it, but the screws? are very tight. Do I just use a vice grip and pull them? They don't look like reusable, but I don't know. I don't want to break them so I am asking here. Please let me know. Thank you. Link to comment Share on other sites More sharing options...
fasteddyT5 Posted November 1, 2011 Report Share Posted November 1, 2011 Those aren't screws they are rivets. You can pull them out with a set of vice grips, but just be careful not to damage the holes that they run through. Or you can drill them out. And yes, they are not reusable. You can get new black ones from the dealer or ipd (possibly fcp), but you can also use standard pop-rivets which run pretty cheap, or just use some nuts and bolts if you don't have a rivet tool. Link to comment Share on other sites More sharing options...
FAST850R Posted November 1, 2011 Author Report Share Posted November 1, 2011 Those aren't screws they are rivets. You can pull them out with a set of vice grips, but just be careful not to damage the holes that they run through. Or you can drill them out. And yes, they are not reusable. You can get new black ones from the dealer or ipd (possibly fcp), but you can also use standard pop-rivets which run pretty cheap, or just use some nuts and bolts if you don't have a rivet tool. Thank you very much for the advice. I will try to use some bolts since I don't have a rivet tool. Link to comment Share on other sites More sharing options...
BEJinFBK Posted November 1, 2011 Report Share Posted November 1, 2011 I wouldn't recommend using vise grips. You'll tear up the holes and make a mess. Drilling or cutting the heads off very carefully with a dremel cutoff wheel works well. And if you haven't got a rivet gun, you can get'em cheap. There are several places on your Volvo you may need one later. And they're just a good tool to have. The OEM rivets usually pretty cheap, if your local dealer isn't a crook, and should be in stock at any decent Vovlo dealer parts counter. Link to comment Share on other sites More sharing options...
bergmjs Posted November 1, 2011 Report Share Posted November 1, 2011 Just get a small pair of wire cutters. Slip the blade tips under the rivet head and cut the head off, won't damage the hole and cuts them out fine. Link to comment Share on other sites More sharing options...
FAST850R Posted November 1, 2011 Author Report Share Posted November 1, 2011 Thank you for the tips. I couldn't take out the rivet because a vice grip was going to tear the wholes. I guess I need to buy the rivet gun. Link to comment Share on other sites More sharing options...
BEJinFBK Posted November 2, 2011 Report Share Posted November 2, 2011 Just get a small pair of wire cutters. Slip the blade tips under the rivet head and cut the head off, won't damage the hole and cuts them out fine. +1 - With the right cutters, that works pretty well, too. Link to comment Share on other sites More sharing options...
James A Sousa Posted November 4, 2011 Report Share Posted November 4, 2011 I recommend that you get the Volvo rivets - I have changed two front bumpers and I found that cheap rivets do not hold as well as the Volvo ones. I think that the volvo ones are just a bit larger When you do the job, I suggest that you put nails in all the holes to line them up. then replace them with rivets, starting from the middle. This keeps all the holes lined up well enough so that any small errors do not add up and make it hard to put the last one or two in place. Link to comment Share on other sites More sharing options...
bergmjs Posted November 4, 2011 Report Share Posted November 4, 2011 When you put each rivet in, theres still a bit of wiggle until all of them are in, so lining up all the holes at once isn't too critical. Once you get 2 rivets in they should all be lined up, just make sure the plastic tab of the mudflap is in the metal clip on the bottom of the side-skirt. I bought some of the body rivets from FCP and the rubber surrounds on them just cracked off when you install them, so I just use standard aluminum rivets that are the size of the hole. A box of rivets for $3 is much better than the Volvo rivets that are like $1 each. Link to comment Share on other sites More sharing options...
db130 Posted November 4, 2011 Report Share Posted November 4, 2011 part number for the volvo rivets is 979878(sometimes you need the the full part number which is 979878-6). MSRP $.83 each I use a Marson HP-2 rivet gun which could be had for $21 shipped on ebay, Link to comment Share on other sites More sharing options...
Malvasi Posted November 7, 2011 Report Share Posted November 7, 2011 This is good info to know since I am going to have to reinstall mine on the T5-R. Good thread guys Link to comment Share on other sites More sharing options...
Yellow95 Posted November 7, 2011 Report Share Posted November 7, 2011 I replace all the rivets with plastic trim plugs on all my cars. You can get them at any auto parts store. Gary Link to comment Share on other sites More sharing options...
