lookforjoe Posted November 12, 2011 Report Share Posted November 12, 2011 I just wonder if you need ONLY the boot, can you use the GKN Boot Kit ($10 online) used for 1998 V70FWD and somehow improvise and fit in your drive shaft. As long as you have a good seal, who cares how you do it. Just a thought! No. coloradodriveshaft sells the proper boot, the flange is integral to the boot, and there are two sizes, they have both versions. Boots are about $50 typical worn boot as long as the CV is NOT bone dry of grease, they are usually fine once cleaned Link to comment Share on other sites More sharing options...
Keaton85 Posted November 12, 2011 Report Share Posted November 12, 2011 Link to comment Share on other sites More sharing options...
831t5r Posted November 13, 2011 Report Share Posted November 13, 2011 Yea volvo sells em to just cant get the boot only. Comes with joint Link to comment Share on other sites More sharing options...
lookforjoe Posted November 13, 2011 Report Share Posted November 13, 2011 Price wise, the Volvo unit isn't bad for joint + boot - but just the boot can also be bought from PegasusRacing (I believe ours are the later 94mm vs earlier 108mm bolt circle, I'd double check before ordering, though... Link to comment Share on other sites More sharing options...
notaduc Posted November 14, 2011 Author Report Share Posted November 14, 2011 Mine are 74mm pcd with 86mm od. Link to comment Share on other sites More sharing options...
lookforjoe Posted November 14, 2011 Report Share Posted November 14, 2011 Mine are 74mm pcd with 86mm od. ..Then get them from Coloradodriveshaft as mentioned before. Pegasus seems cheaper, but if they're not the correct size, that doesn't help, does it. You could always call them & see if they carry the smaller Volvo spec size. Link to comment Share on other sites More sharing options...
notaduc Posted November 14, 2011 Author Report Share Posted November 14, 2011 Yea, I spoke with David at colorado last week, he confirmed he has the correct boots in stock, $36 each.... Link to comment Share on other sites More sharing options...
Che'_Moderator Posted November 14, 2011 Report Share Posted November 14, 2011 Yea, I spoke with David at colorado last week, he confirmed he has the correct boots in stock, $36 each.... You can buy the entire unit for that. Link to comment Share on other sites More sharing options...
notaduc Posted November 14, 2011 Author Report Share Posted November 14, 2011 You can buy the entire unit for that. Entire cv? For $36, where? Link to comment Share on other sites More sharing options...
Keaton85 Posted November 15, 2011 Report Share Posted November 15, 2011 As noted by the photo I added that a universal CV boot fits. worked perfect and cost hardly anything..... Link to comment Share on other sites More sharing options...
