vivalavolvo Posted November 19, 2011 Report Share Posted November 19, 2011 When ever i make a hard stop or decelerate quickly i get this strange hesitation/loss of power feeling for a second or two. I just did the motor mounts today thinking that may have been it, but nope. It almost feels like the trans doesn't know what gear to go into or something. Its a 95 855 T5 Auto. Any input is appreciated. Link to comment Share on other sites More sharing options...
Zappo Posted November 19, 2011 Report Share Posted November 19, 2011 Check your postive battery terminal, especially the wires bolted to it. If they are lose, that would cause your problem. Link to comment Share on other sites More sharing options...
vivalavolvo Posted November 20, 2011 Author Report Share Posted November 20, 2011 Check your postive battery terminal, especially the wires bolted to it. If they are lose, that would cause your problem. Will do. My 240 had a similar issue. Link to comment Share on other sites More sharing options...
bergmjs Posted November 20, 2011 Report Share Posted November 20, 2011 Check your transmission fluid level, sounds like low fluid to me. Note that when checking the transmission fluid level, the "Cold" section on the dipstick is for after 15 minutes of idling from a cold start and the "Hot" section is for after at least 30 minutes of highway driving. Link to comment Share on other sites More sharing options...
Jardim Posted November 20, 2011 Report Share Posted November 20, 2011 Does it feel like a engine hesitation? or a tranny hesitation. Vaccum leaks can cause engines to hesitate under WOT.edit: WOW im dumb, i read the tittle as "heavy acceleration" ignore this Link to comment Share on other sites More sharing options...
vivalavolvo Posted November 20, 2011 Author Report Share Posted November 20, 2011 Check your transmission fluid level, sounds like low fluid to me. Note that when checking the transmission fluid level, the "Cold" section on the dipstick is for after 15 minutes of idling from a cold start and the "Hot" section is for after at least 30 minutes of highway driving. 1,000 points are to be rewarded to you sir. Link to comment Share on other sites More sharing options...
