boxpin Posted November 21, 2011 Report Share Posted November 21, 2011 I have read the manual swap thread but my wires are not matching up to the colors. I dont have a blue with a white. Does anyone recognize which wires I need? There are two fat ones and two skinnys. Link to comment Share on other sites More sharing options...
Volvo5.0 Posted November 21, 2011 Report Share Posted November 21, 2011 My schematic shows the blue/green wire and the blue wire. Edit: It is the BLUE/GRAY (pin 9) wire and the BLUE (pin 5) wire. Link to comment Share on other sites More sharing options...
lookforjoe Posted November 21, 2011 Report Share Posted November 21, 2011 The pins are numbered in that plug - disassemble it to see the pin #'s I used: For Reverse Use Pin 9 (Blue-Green Blue-Gray +) & Pin 5 (Blue - feed to lights). There is more than one solid blue wire, as you have found! Link to comment Share on other sites More sharing options...
boxpin Posted November 21, 2011 Author Report Share Posted November 21, 2011 Thanks, pulled the plug apart...it was the two fat wires in the picture. Link to comment Share on other sites More sharing options...
atefitty Posted April 10, 2012 Report Share Posted April 10, 2012 Following the information I got reading this forum I used the blue blue/gray wire and it did not work..My chilton manual says blue green wires. The hot wire is always hot according to chilton...the blue gray wire is only hot with key on..I checked at the fuse box.. still confused on why it does not work if I have power with key on though. Link to comment Share on other sites More sharing options...
atefitty Posted April 11, 2012 Report Share Posted April 11, 2012 I bypassed the reverse light switch last nigh with the blue blue/gray wires and the lights came on.. Link to comment Share on other sites More sharing options...
Jardim Posted April 15, 2012 Report Share Posted April 15, 2012 Weird, when i did my swap the Haynes Manual said "BLUE & BLUE/GREEN" but it didnt work so till this day i was stuck with no reverse lights..... Then i read your comment "BLUE & BLUE/GRAY"....tried that combo out and they came on when i put it in reverse.... 94 850 Turbo....Its rather strange but could certain years have different color setup on the TCU plug? Link to comment Share on other sites More sharing options...
Volvo5.0 Posted April 16, 2012 Report Share Posted April 16, 2012 Weird, when i did my swap the Haynes Manual said "BLUE & BLUE/GREEN" but it didnt work so till this day i was stuck with no reverse lights..... Then i read your comment "BLUE & BLUE/GRAY"....tried that combo out and they came on when i put it in reverse.... 94 850 Turbo....Its rather strange but could certain years have different color setup on the TCU plug? I looked again to be sure, and you're right, it is the Blue (pin 5) and BLUE/GRAY (pin 9) wires. It is the same for 850's and X/70's. Edited my first post to make it correct. Link to comment Share on other sites More sharing options...
scandalo Posted April 16, 2012 Report Share Posted April 16, 2012 Thread revive! We ran into this thread doing the M66 and we were like "well this isn't the wire he said but it sure looks right" :lol. Thank you for changing that. This was one of the first threads that came up on google. Link to comment Share on other sites More sharing options...
Jardim Posted April 16, 2012 Report Share Posted April 16, 2012 :arob: 4 months with no reverse lights and backing up out of pitch black driveways with a flashlight FML Link to comment Share on other sites More sharing options...
atefitty Posted April 16, 2012 Report Share Posted April 16, 2012 Got my reverse light swith from IPd...used Blue Blue Gray wires and all is good..Well except for my damn clutch that I can't seem to bleed for the life of me.. Link to comment Share on other sites More sharing options...
Jardim Posted April 16, 2012 Report Share Posted April 16, 2012 Go do that sheit and drive your car!!!!!!!! Link to comment Share on other sites More sharing options...
dublin14 Posted April 16, 2012 Report Share Posted April 16, 2012 A little off topic... My pal Kyle (boglin) as he used be called on VS is the parts manager at my local Volvo. He was a down at a Volvo conference in Texas last week and text me to say they had a 400hp Polstar C30 there that uses the 850R SM flywheel and clutch. Anyways, Volvo and Polstar said the 850R SM Flywheel clutch setup was the best they have made to date. Which for us that use it is nice to hear. Mine is cryo treated, so its even better B) Link to comment Share on other sites More sharing options...
