SRTthis Posted December 21, 2011 Author Report Share Posted December 21, 2011 thats how i had it timed... talked to an ex volvo tech over on yellowbullet and he said i need to turn the VVT cam 90 past the mark then back into place. im going to give it a shot next week when im off along with a few other things. Link to comment Share on other sites More sharing options...
Gilhuly Posted December 22, 2011 Report Share Posted December 22, 2011 I usually don't hang out here with the new cars, but I know how to handle this. Set the notches on the drivers side level with the deck. The exhaust gear will be way off. This is where you need a cam locking device or another person. I stuck a piece of angle iron in the slot and put vise grips on it or something. Have your buddy hold the exhaust cam in place while you twist the gear counter clock all the way and then let it back enough to catch the first available tooth and get the belt on. Trust me that's the clearest explanation you'll find on the internet. Link to comment Share on other sites More sharing options...
SRTthis Posted December 22, 2011 Author Report Share Posted December 22, 2011 I usually don't hang out here with the new cars, but I know how to handle this. Set the notches on the drivers side level with the deck. The exhaust gear will be way off. This is where you need a cam locking device or another person. I stuck a piece of angle iron in the slot and put vise grips on it or something. Have your buddy hold the exhaust cam in place while you twist the gear counter clock all the way and then let it back enough to catch the first available tooth and get the belt on. Trust me that's the clearest explanation you'll find on the internet. thats how i have it sitting right now with the exhaust cam slot parallel with the deck. but my VVT hub automatically pulls counter clock. so the exhaust cam mark wont line up at all? Link to comment Share on other sites More sharing options...
SRTthis Posted January 2, 2012 Author Report Share Posted January 2, 2012 any reports of cam's being 180* out? Link to comment Share on other sites More sharing options...
Volvo5.0 Posted January 2, 2012 Report Share Posted January 2, 2012 any reports of cam's being 180* out? This is what the cams should look like when viewed from the rear. Make sure the slots are offset as shown or you could be 180 out.... . Link to comment Share on other sites More sharing options...
SRTthis Posted January 2, 2012 Author Report Share Posted January 2, 2012 This is what the cams should look like when viewed from the rear. Make sure the slots are offset as shown or you could be 180 out.... . perfect! thanks man! Link to comment Share on other sites More sharing options...
SRTthis Posted January 4, 2012 Author Report Share Posted January 4, 2012 Cams are timed right... well time to figure out why no spark Link to comment Share on other sites More sharing options...
SRTthis Posted January 5, 2012 Author Report Share Posted January 5, 2012 http://www.___.com/forums/viewtopic.php?f=1&t=40613 found this which sounds like my problem exactly... i have fuel but no spark and can get it to turn over. looks like i need to test my cam sensor and my flywheel sensor. Link to comment Share on other sites More sharing options...
SRTthis Posted January 6, 2012 Author Report Share Posted January 6, 2012 RUNS! forgot the coil ground for cyl 3 4 5 whoops Link to comment Share on other sites More sharing options...
