Custom Desktop Computers
InitialDriveGTR
My best laptop is an HP 8560
32gb ddr3 RAM
2 Intel 600gb SSDs in RAID 0 making 1.2tb
Core i7 2.5ghz quad core hyperthreaded
I run 20 Windows 7 virtual machines and a domain environment of server VMs (23 total) for large scale deployment demos and it doesn't lag at all. First machine I've ever owned that maxes out all of the winsat scores except for GPU - even that is 7.6 out of 7.9.
Great workhorse laptop. But man, you spent as much on those SSDs as the laptop is worth! Must be screaming. IPS screen option?
Curious as to how you setup RAID 0 with your SSDs. The biggest thing against RAID on SSDs is that it works against the built in wear-leveling (ala TRIM), with these Intel SSDs (if using Intel RST) I believe that it turns off TRIM support. Which means it defaults to the internal garbage collection? Not sure if that's positive, but I'm guessing it would do that.
  • Replies 177
Don't think so. These SSDs have not yet started to fall off like other SSDs I have killed in RAID (Kingston 512gb units). I'm on month three and abuse them pretty badly. If they get bad or slow, i will replace them.
I can't get my head around replacing SSD's like that lol
i want to savagely beat the person who installed bright leds (one white, one blue) on my motherboard that you cant turn off. Ohhh, and ill use the ripped off limbs from the guy who made the case with what appears to be a flashlight led on the front, to beat the motherboard guy.
I dont mind the look of leds for the case, but they must be red.
LOL, I painted my Lexan side panels black so the innards are hidden from view. Everything you buy these days have LEDs in them, fans, powersupplies, motherboards... Then it illuminates the dust bunnies inside the case. Then no matter how tidy you try to make it, PC's always end up looking like a hot mess inside.
Nahhh it's all about management. and use filters on the intake fans. as long as there is no dust inside to begin with, and you don't let any in, it stays clean
Yeah, yours look clean. Back in the day with IDE/ATA cables...oh what a nightmare! Thumbs up for SATA.
I ended up doing this to my Lexan panel.
