stereophile33 Posted January 2, 2012 Report Share Posted January 2, 2012 I've got the unit all hooked up, but what do I need to fill the gaps? Are there any kits around? Jonathan Link to comment Share on other sites More sharing options...
BEJinFBK Posted January 2, 2012 Report Share Posted January 2, 2012 Make and model? If your DD didn't come with a factory trim plate in the box, check with the manufactor and see if it's available. The factory trim, ( if you can get it ) will have a perfect fit around the nose of the HU. That's usually the more challanging part of the job. Then, if it needs it ( and it often does ) you just mod the outside to fit the dash. Otherwise, you'll probably have to custom fab it from some ABS flat stock. Link to comment Share on other sites More sharing options...
andyb5 Posted January 4, 2012 Report Share Posted January 4, 2012 Buy a sheet of 1/16" ABS, then measure, and cut. Simple as can be Link to comment Share on other sites More sharing options...
Josh Estepp Posted April 15, 2012 Report Share Posted April 15, 2012 Should have came with trim pieces or check for a Metra double din kit for volvo. Link to comment Share on other sites More sharing options...
andyb5 Posted April 16, 2012 Report Share Posted April 16, 2012 Metra/Schosche don't make a dash kit for 98-00 x70s. Link to comment Share on other sites More sharing options...
j.klimas Posted June 25, 2012 Report Share Posted June 25, 2012 I had to jerry rig a using some metal shelving supports, shims, and double sided tape. Doesnt look all that bad once its covered with the plastic faceplate. (should have come with the HU) Link to comment Share on other sites More sharing options...
