damitzmike Posted January 7, 2012 Report Share Posted January 7, 2012 I took my 96 850R to Ntb today to get a wheel alighnment. They said that the left rear wheel had a camber of -0.3 and couldnt be zero'd out do to bolt isues...... ive searched online for camber bolts but only found kits for the front. Any idea's? Link to comment Share on other sites More sharing options...
Dan A Posted January 9, 2012 Report Share Posted January 9, 2012 I don't believe there is any factory adjustment. But I also don't think that measurement is out of acceptable range. Edit: Never mind, it is slightly out of range (-1.5 to -0.5). Check for trailing arm damage. Link to comment Share on other sites More sharing options...
VulVer Posted January 10, 2012 Report Share Posted January 10, 2012 Yes I had this same problem. My trailing arm only passenger rear side was totally spent. If I looked at the car from the rear you can accually see the angle of the tire if you fix it it straightens it back out. Get it at FCP Groton is alot more inexpensive. But if you don't have a lift I recomend paying a shop to do it. It is a huge pain in the A S S to get out. Do not try this in your drive way.Also what causes the rear trailing arm to go is worn shocks so check those out as well. Link to comment Share on other sites More sharing options...
