silegnav Posted March 16, 2005 Report Share Posted March 16, 2005 i've read that the camber goes out of wack once you start lowering the suspension. did you have to get one of those special camber adjustment kits to fix any camber issues, if any? if you did which one did you get?thanksv Link to comment Share on other sites More sharing options...
dancetheman Posted March 16, 2005 Report Share Posted March 16, 2005 neg camber in the front ain't too bad...helps you with understeer (so i've heard) and when you drive normally, it will wear the inside of your tires and when you turn hard it will wear the outsideeven wear!! for directionals anyways Link to comment Share on other sites More sharing options...
nik850r Posted March 16, 2005 Report Share Posted March 16, 2005 i've read that the camber goes out of wack once you start lowering the suspension. did you have to get one of those special camber adjustment kits to fix any camber issues, if any? if you did which one did you get?thanksv←i used the camber kit from est when i did my suspension upgrade Link to comment Share on other sites More sharing options...
BeachRat Posted March 16, 2005 Author Report Share Posted March 16, 2005 neg camber in the front ain't too bad...helps you with understeer (so i've heard) and when you drive normally, it will wear the inside of your tires and when you turn hard it will wear the outsideeven wear!! for directionals anyways←There's a little bit of camber as a result of removing/re-bolting the steering knuckle, but that's fixed with an alignment.That's the idea: on hard turns the lateral force actually tends to straighten out a negatively cambered wheel. You toe-in the front wheels on an FWD setup and the rear wheels on a RWD setup. But it's really only for a track car/track day. Daily driving will wear down the edges of your tires way too much, and it's just not worth the understeer it helps. Link to comment Share on other sites More sharing options...
