Brad850 Posted February 26, 2012 Author Report Share Posted February 26, 2012 Ah ok thanks...I see my problem now is I didn't take off the oil pump gear I'm guessing that's supposed to slide off? Link to comment Share on other sites More sharing options...
SlapShot Posted February 26, 2012 Report Share Posted February 26, 2012 Yes, that needs to come off to remove the oil pump. I rented the bigger of the two pullers that Autozone has. Came off pretty easily. Link to comment Share on other sites More sharing options...
Brad850 Posted February 27, 2012 Author Report Share Posted February 27, 2012 Got it off. You guys are life savers. Link to comment Share on other sites More sharing options...
z31jaime Posted February 28, 2012 Report Share Posted February 28, 2012 I'll almost bet mony that if they used that much sealer on the oil pan, they put lock tight on the bolts you broke off. This happened to me recently why changing a thermostat. the person Put lock tight and I ended up snapping both bolts. Next time you run into that issue try heating up the bolts with a torch and then turning them. this melts the lock tight and they come off super easy. Link to comment Share on other sites More sharing options...
Brad850 Posted March 8, 2012 Author Report Share Posted March 8, 2012 Anyone have the torque/angle specs for the three different intermediate block bolts? Link to comment Share on other sites More sharing options...
Volvo5.0 Posted March 8, 2012 Report Share Posted March 8, 2012 Here are the torque specs. The large bolts should be replaced since they are stretch bolts, although I know some people re-use them.... Link to comment Share on other sites More sharing options...
Brad850 Posted March 8, 2012 Author Report Share Posted March 8, 2012 Thank you! I did buy new stretch bolts. 76 dollars :glare: Link to comment Share on other sites More sharing options...
Brad850 Posted March 11, 2012 Author Report Share Posted March 11, 2012 How important is it for the mating surface (on the block) to be absolutely clear of all the sealant residue? Took me about 3 hours to get 95 percent of it off. There's still a few spots with a brownish film that are going to be hard to get to. Are those spots not going to seal? Link to comment Share on other sites More sharing options...
