Oreo931 Posted February 8, 2012 Report Share Posted February 8, 2012 I believe the rates were 350. But the ride on these are substantially better. I also had the Konis on the softest setting. I guess I'll have to ride in a car with TAs to believe it. Doesn't make sense that a non dampening adjustable coil over with a higher spring rate rides nicer than hacked up adjustable konis with a softer spring rate. Not calling you a liar, I I just want to see for myself. Ride quality is subjective anyway. Link to comment Share on other sites More sharing options...
BtownVolvo Posted February 8, 2012 Report Share Posted February 8, 2012 Koni DIY's with a linear spring is straight awful to ride on. Link to comment Share on other sites More sharing options...
Oreo931 Posted February 8, 2012 Report Share Posted February 8, 2012 Hmmm...I wish someone locally had these for me to try out. Link to comment Share on other sites More sharing options...
gilber33 Posted February 8, 2012 Report Share Posted February 8, 2012 Hmmm...I wish someone locally had these for me to try out. I wish you could. Because these compared to the Koni DIYs I had make the Konis straight awful. I love the ride on these. Link to comment Share on other sites More sharing options...
pedro fandango Posted February 8, 2012 Report Share Posted February 8, 2012 so what are the options for lowering the back even more? Are shorter versions available in this configuration. Or can we cut the springs down Link to comment Share on other sites More sharing options...
fischmama Posted February 8, 2012 Author Report Share Posted February 8, 2012 I want to say that you can cut at least half a coil (1/2 - 1" ?) and take out the adjustable seat in the rear (1/4" +) to drop it a bit. Or go with set up that I have from RSI. 5" adjustable perches from the 240 series and 5" x 8.5" springs (mine are 300#). Link to comment Share on other sites More sharing options...
BtownVolvo Posted February 8, 2012 Report Share Posted February 8, 2012 so what are the options for lowering the back even more? Are shorter versions available in this configuration. Or can we cut the springs down From what I gather, you can remove the adjustable plate all together and drop a little more. Cutting any spring (in general) is just not a good idea. You're better off finding a smaller spring. Link to comment Share on other sites More sharing options...
fischmama Posted February 8, 2012 Author Report Share Posted February 8, 2012 From what I gather, you can remove the adjustable plate all together and gain another couple inches. Cutting any spring (in general) is just not a good idea. You're better off finding a smaller spring. Its a dead coil from what it looks like, but you are still correct. I can't find my stock bottom spring mounts to see if they will fit. Gabe, Do you still have yours? Can you see if they would work. Link to comment Share on other sites More sharing options...
gilber33 Posted February 8, 2012 Report Share Posted February 8, 2012 Its a dead coil from what it looks like, but you are still correct. I can't find my stock bottom spring mounts to see if they will fit. Gabe, Do you still have yours? Can you see if they would work. Yeah, I still both mine and your rear springs and my Dad's sawzall. I can take a couple coils off and toss them in and see what kind of drop/ride they give. Link to comment Share on other sites More sharing options...
BtownVolvo Posted February 8, 2012 Report Share Posted February 8, 2012 LOL I just realized I typed "couple inches" for removing the perch. Woops...edited. Link to comment Share on other sites More sharing options...
gilber33 Posted February 8, 2012 Report Share Posted February 8, 2012 I basically was trying to state that you get what you pay for lol. Understandable. I hear you. I just wanted to make it clear that if you do decide to remove the helper springs on these, it will not give you a harsh ride...at least compared to the Koni DIYs which were extremely harsh. IMO, these are very smooth with the helper spring removed. Link to comment Share on other sites More sharing options...
Oreo931 Posted February 8, 2012 Report Share Posted February 8, 2012 Anyone want to lend me their front TAs to try out? If they really do ride nicer I'll buy a set tomorrow :) Link to comment Share on other sites More sharing options...
B Mac Posted February 9, 2012 Report Share Posted February 9, 2012 Koni DIY's with a linear spring is straight awful to ride on. Probably, but has anyone shortened the strut at all to compensate for going so low with a spring? Idk if it is possible with konis bc of the adjustment screw but guys on TBricks are shortening (bilstien I assume) struts for 240s and it just makes sense in general. Link to comment Share on other sites More sharing options...
sacrifice Posted February 9, 2012 Report Share Posted February 9, 2012 I don't think anyone has shortened the yellows to compensate for height and spring rate. But then the argument arrises that if you are going to be doing that much custom work you might as well just purchase a set of coilovers for $600. Link to comment Share on other sites More sharing options...
BtownVolvo Posted February 9, 2012 Report Share Posted February 9, 2012 I don't think anyone has shortened the yellows to compensate for height and spring rate. But then the argument arrises that if you are going to be doing that much custom work you might as well just purchase a set of coilovers for $600. If you're removing helper springs and swapping in other springs, then we're back at the same place. Probably, but has anyone shortened the strut at all to compensate for going so low with a spring? Idk if it is possible with konis bc of the adjustment screw but guys on TBricks are shortening (bilstien I assume) struts for 240s and it just makes sense in general. Good point. I'd be interested in seeing something like FSD's shortened since they're valved. I'm pretty sure you can shorten Yellows since they're rebuildable. Makes sense to me. Link to comment Share on other sites More sharing options...
