Iloveboost Posted February 12, 2012 Report Share Posted February 12, 2012 So i am installing an amo and sub in my 2002 S60 T5. The amp is an older kicker zx300.1. My question is that the amp has speaker level inputs but i do not have the harness. I know i could use a line output convertor but this would save me a few if i could use it. It is label which wires go where so theoretically i should be able to run wires to the prongs sticking out. The problem is doing this without shorting them out. Is there some sort of connector i could use? Here is a picture of the plug. Thanks guys! Link to comment Share on other sites More sharing options...
BEJinFBK Posted February 12, 2012 Report Share Posted February 12, 2012 Find out which shops in your area install Kicker. More than likely, they have a stray harness. Link to comment Share on other sites More sharing options...
andyb5 Posted February 12, 2012 Report Share Posted February 12, 2012 Ebay or Amazon will be your friend here Link to comment Share on other sites More sharing options...
Piston Slapper Posted February 14, 2012 Report Share Posted February 14, 2012 That looks suspiciously similar to the 4 pin connector used by internal computer fans. Might be able to get a wire tail by cutting off the connector on one of those. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted February 14, 2012 Report Share Posted February 14, 2012 I have a couple around here some where. Speaker level sounds like ass though. You really want to be using line level outs. RCA cables are cheap. Link to comment Share on other sites More sharing options...
Piston Slapper Posted February 14, 2012 Report Share Posted February 14, 2012 I have a couple around here some where. Speaker level sounds like ALL GLORY TO THE HYPNOTOAD though. You really want to be using line level outs. RCA cables are cheap. Amen, sub preamp outs are definitely the way to go if at all possible. Does you head unit not have them? Link to comment Share on other sites More sharing options...
