FAST850R Posted February 29, 2012 Report Share Posted February 29, 2012 Hello, I just now finished installing front shocks for 1996 850r. I'm about to work on rear tomorrow. I have read some DIY threads and found out that I need to pb blast those bolts. So after pb blasting them, can I just use an impact wrench to unbolt them? It looks like they are easy to break, but I'm not so sure. Thanks Link to comment Share on other sites More sharing options...
Dick Dastardly Posted February 29, 2012 Report Share Posted February 29, 2012 Impact should take them off. They might start spinning (the shaft) in which case you would need an offset (14 or 15mm?? can't remember atm) box wrench and I think a 7mm open end or an allen key (depending on what brand of shock) to hold the shaft in place.. Link to comment Share on other sites More sharing options...
ozzimark Posted February 29, 2012 Report Share Posted February 29, 2012 Shouldn't be too hard to break free. I loosened mine with an 18" breaker bar, then used an open-end wrench with an allen wrench to prevent it from spinning to get it the rest of the way off. Link to comment Share on other sites More sharing options...
JVC Posted February 29, 2012 Report Share Posted February 29, 2012 Impact is king with those things. Link to comment Share on other sites More sharing options...
FAST850R Posted February 29, 2012 Author Report Share Posted February 29, 2012 Thank you for the replies. I guess it's ok to use an impact wrench for the bolts. It helped a lot while I was working on front shocks. I highly recommend it to anybody who is going to replace shocks.Oh by the way, I am talking about the 2 bolts that hold rear shocks. Not the center one....sorry if I make you guys confused. Link to comment Share on other sites More sharing options...
erikv11 Posted February 29, 2012 Report Share Posted February 29, 2012 If you are talking about the two shock mount bolts, I would never hit them with an impact. They are prone to breakage and/or breaking off the nut that is welded to the frame underneath. I would hit them with PBblaster from below, then loosen them slowly. Unscrew a little, get a dab of PB in there, thread back down. The problem is the threads are exposed so they get very rusty. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted February 29, 2012 Report Share Posted February 29, 2012 If you are talking about the two shock mount bolts, I would never hit them with an impact. They are prone to breakage and/or breaking off the nut that is welded to the frame underneath. I would hit them with PBblaster from below, then loosen them slowly. Unscrew a little, get a dab of PB in there, thread back down. The problem is the threads are exposed so they get very rusty. Yeah..careful with these. I assumed he meant the center nut. Link to comment Share on other sites More sharing options...
Matty Moo Posted February 29, 2012 Report Share Posted February 29, 2012 Impact is king with those things. Hell yes. Only takes seconds to get them off, with no spinning. Link to comment Share on other sites More sharing options...
FAST850R Posted February 29, 2012 Author Report Share Posted February 29, 2012 Thank you for the replies. I'll take time to unbolt them. I'll use an impact wrench for the top middle bolt :) Link to comment Share on other sites More sharing options...
