kwells114 Posted February 29, 2012 Report Share Posted February 29, 2012 Alternator is loose. How do I get it out, bracket is in the way. Do I need to completely unbolt the AC compressor to remove the bracket? I've looked at other posts, all seem to get it out without taking bracket off. Thanks for help Link to comment Share on other sites More sharing options...
Keaton85 Posted February 29, 2012 Report Share Posted February 29, 2012 You have to move the PS out of the way and take off the coolant hose. Then it just wiggles out... The PS pump is only held on with a couple bolts and kinda just folds out of the way... Link to comment Share on other sites More sharing options...
kwells114 Posted February 29, 2012 Author Report Share Posted February 29, 2012 Thanks. PS pump went out first, then top coolant hose, as well as lower air intake hose from cooler (to get at lower AC bolts). It's either this bracket, or the radiator has to come out. No way to get it out unless I get the crow bar out, then I'm going to break something... Link to comment Share on other sites More sharing options...
Keaton85 Posted February 29, 2012 Report Share Posted February 29, 2012 Did you loosen the bottom two AC compressor bolts? It should just slide right out! Link to comment Share on other sites More sharing options...
kwells114 Posted February 29, 2012 Author Report Share Posted February 29, 2012 Alt is loose. Just can't get it out of engine compartment. Normally Volvo is a very easy car to work on, except this. All other cars it's a 15 min. job. Grrrrrrrrrr Link to comment Share on other sites More sharing options...
Volvo5.0 Posted February 29, 2012 Report Share Posted February 29, 2012 It's kind of like a puzzle. If you get it turned just right it will magically come out. With that said, I've also "gently" used a pry bar on the engine to get that little extra room that's needed. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted February 29, 2012 Report Share Posted February 29, 2012 No need to take the radiator out. It's a tight squeeze just try a few different angles, you'll get it. Link to comment Share on other sites More sharing options...
Keaton85 Posted February 29, 2012 Report Share Posted February 29, 2012 Like I said did you loosen the AC compressor? Link to comment Share on other sites More sharing options...
kwells114 Posted February 29, 2012 Author Report Share Posted February 29, 2012 Thanks all. Out to give it another try. I'll post results later. Link to comment Share on other sites More sharing options...
kwells114 Posted February 29, 2012 Author Report Share Posted February 29, 2012 Ok, it's out. Forced it. Plastic radiator inlet flange a little scarred up, metal part of flange is good. Thanks for help / encouragement. Kev Link to comment Share on other sites More sharing options...
