Jesus Posted March 2, 2012 Report Share Posted March 2, 2012 Just wish the springs were an inch or two shorter and a smidge stiffer all around. What worked for you and where did you get them? Link to comment Share on other sites More sharing options...
fischmama Posted March 2, 2012 Report Share Posted March 2, 2012 Doesn't D2 publish the spring rates? Link to comment Share on other sites More sharing options...
Piston Slapper Posted March 2, 2012 Report Share Posted March 2, 2012 You'd need to know the springs diameter, probably of the two standard coilover sizes, and then you could order springs in basically any rate and length you wanted. Link to comment Share on other sites More sharing options...
gilber33 Posted March 2, 2012 Report Share Posted March 2, 2012 Just wish the springs were an inch or two shorter and a smidge stiffer all around. What worked for you and where did you get them? Vogtland B5 Audi rear coilover springs Compared to TA springs On the car Stiff as fuck. Bottom diameter is a smidge wider than factor springs, and the very top dead coil cut, the springs sit perfectly in the factory upper spring seat. Link to comment Share on other sites More sharing options...
andyb5 Posted March 2, 2012 Report Share Posted March 2, 2012 The front springs are 480 lb/in rears are 250 lb/in. Going off appearances only, the fronts seem to be a standard coilover spring, whereas the rears seem to be custom-made for the application. Link to comment Share on other sites More sharing options...
Piston Slapper Posted March 2, 2012 Report Share Posted March 2, 2012 Know the IDs on them? There are larger ID springs out there. Link to comment Share on other sites More sharing options...
andyb5 Posted March 2, 2012 Report Share Posted March 2, 2012 They're tapered, that's why it seems like those might be harder to replace: Link to comment Share on other sites More sharing options...
Piston Slapper Posted March 2, 2012 Report Share Posted March 2, 2012 Oh, ya, that might be tricky. Link to comment Share on other sites More sharing options...
gilber33 Posted March 2, 2012 Report Share Posted March 2, 2012 They're still the 2.5" bottom with a 5" top. Or, get a TKI upper perches and run a 2.5" coil spring. Link to comment Share on other sites More sharing options...
Piston Slapper Posted March 2, 2012 Report Share Posted March 2, 2012 They're still the 2.5" bottom with a 5" top. Or, get a TKI upper perches and run a 2.5" coil spring. That would make things very simple indeed. Link to comment Share on other sites More sharing options...
JVC Posted March 2, 2012 Report Share Posted March 2, 2012 I was going to have some upper rear perches made then use a 2.5" spring in the rear. Ask Kalvin since I know he just got some 7" coil springs that were 450 and 350 IIRC. Link to comment Share on other sites More sharing options...
Jesus Posted March 2, 2012 Author Report Share Posted March 2, 2012 What's Kalvin's username? Link to comment Share on other sites More sharing options...
gilber33 Posted March 2, 2012 Report Share Posted March 2, 2012 What's Kalvin's username? Kalvin. :lol: Link to comment Share on other sites More sharing options...
Zappo Posted March 2, 2012 Report Share Posted March 2, 2012 I was going to have some upper rear perches made then use a 2.5" spring in the rear. Ask Kalvin since I know he just got some 7" coil springs that were 450 and 350 IIRC. It looks fairly easy to change the upper perches in the rear to fit standard springs. I have thought about it also since I would like to go with a little stiffer spring in the rear. Link to comment Share on other sites More sharing options...
T5Hammy Posted March 2, 2012 Report Share Posted March 2, 2012 Kalvin. I lawled! Link to comment Share on other sites More sharing options...
