TIZIO AKA 1 HND MEC Posted March 9, 2012 Report Share Posted March 9, 2012 Bought the car a month ago, start working to bring her back. I have in plan to swap the AUTO with the M66 this summer and I would like to keep driving the car. .CAR DRIVE JUST FINE WITH NO PROBLEMS. Transmission side TRANNY BUDGET IS $2000 I got something to work on for a while, I have found out the following CODES: 1.P1618 fault in lead between AW 50-52?? Motronic 4.3....., 2. P 0722 Output shaft Speed Sensor Circuit No Signal, 3. P0733 Gear 3 Incorrect Ratio, 4. P0735 Gear 5 Incorrect Ratio, 5. P0785 Shift/timing Solenoid, <----------------?????? 6. P0717 Turbine/Input Shaft Speed Sensor Circuit No Signal. Engine side BUDGET IS $2000 Original engine have 214.xxx on it , run good, no smoke/shake/vibrations I was torn to swap the engine as well to a newer 04-06 block or rebuilt the one that I have ??? TOY is 2000V70R silver stock . I am gonna start the big search and read/print, meantime ANY Help/Link etc... WILL be GREAT!!!! Thanks, Tizio. Link to comment Share on other sites More sharing options...
FINN Posted March 9, 2012 Report Share Posted March 9, 2012 Awesome good luck with this! Link to comment Share on other sites More sharing options...
550 Posted March 9, 2012 Report Share Posted March 9, 2012 Bought the car a month ago, start working to bring her back. I have in plan to swap the AUTO with the M66 this summer and I would like to keep driving the car. .CAR DRIVE JUST FINE WITH NO PROBLEMS. Transmission side TRANNY BUDGET IS $2000 I got something to work on for a while, I have found out the following CODES: 1.P1618 fault in lead between AW 50-52?? Motronic 4.3....., 2. P 0722 Output shaft Speed Sensor Circuit No Signal, 3. P0733 Gear 3 Incorrect Ratio, 4. P0735 Gear 5 Incorrect Ratio, 5. P0785 Shift/timing Solenoid, <----------------?????? 6. P0717 Turbine/Input Shaft Speed Sensor Circuit No Signal. Engine side BUDGET IS $2000 Original engine have 214.xxx on it , run good, no smoke/shake/vibrations I was torn to swap the engine as well to a newer 04-06 block or rebuilt the one that I have ??? TOY is 2000V70R silver stock . I am gonna start the big search and read/print, meantime ANY Help/Link etc... WILL be GREAT!!!! Thanks, Tizio. You will blow your engine budget fast if you are rebuilding. Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted March 9, 2012 Author Report Share Posted March 9, 2012 Awesome good luck with this! Thanks Val, you have a nice project as well (keep in touch). You will blow your engine budget fast if you are rebuilding. Then I blow this engine and trow in a newer one. Link to comment Share on other sites More sharing options...
550 Posted March 9, 2012 Report Share Posted March 9, 2012 Thanks Val, you have a nice project as well (keep in touch). Then I blow this engine and trow in a newer one. Please re-read what I said. I didn't say you will blow your ENGINE. I'm saying your budget of 2000 to rebuild an engine is unrealistic. Link to comment Share on other sites More sharing options...
volvo Posted March 9, 2012 Report Share Posted March 9, 2012 Then I blow this engine and trow in a newer one. iLOLed. 2000 on a mild rebuild of aftermarket rods, bearings headgasket all gaskets and new rings isnt exactly impossible...if block is in ok enough condition just for re-ringing Link to comment Share on other sites More sharing options...
550 Posted March 9, 2012 Report Share Posted March 9, 2012 Why bother with a rebuild though if your total budget is for 4000 (2000 for engine.) and you won't even be buying a new turbo. Better off sticking that money with a lower mileage engine and just running that. Especially with the "If I blow it, I'll just replace it" mentality. Link to comment Share on other sites More sharing options...
jnderr Posted March 9, 2012 Report Share Posted March 9, 2012 Figure out what your goals are for this build and that can go a long way to determining what path you choose engine wise. Link to comment Share on other sites More sharing options...
Keaton85 Posted March 10, 2012 Report Share Posted March 10, 2012 Why not just go with a 5spd and a RN motor. Unless the rest of the vehicle is in great mechanical condition? Or sell it and buy a 01+ T5M or R Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted March 10, 2012 Author Report Share Posted March 10, 2012 Please re-read what I said. I didn't say you will blow your ENGINE. I'm saying your budget of 2000 to rebuild an engine is unrealistic. I was playing with the words, I know what you mean, I estimate around +/- 2K for the rebuild and you confirm that, Thanks. iLOLed. 2000 on a mild rebuild of aftermarket rods, bearings headgasket all gaskets and new rings isnt exactly impossible... if block is in ok enough condition just for re-ringing This Block is just fine and I have another two around. Why bother with a rebuild though if your total budget is for 4000 (2000 for engine.) and you won't even be buying a new turbo. Better off sticking that money with a lower mileage engine and just running that. Especially with the "If I blow it, I'll just replace it" mentality. Just swap the engine is not much fun ,rebuild bring fun and different TURBO(later) but take also more time (I think that way and don't have much now) Any suggestion for a bigger turbo? Thanks. Figure out what your goals are for this build and that can go a long way to determining what path you choose engine wise. Bulls eye. Why not just go with a 5spd and a RN motor. Unless the rest of the vehicle is in great mechanical condition? Or sell it and buy a 01+ T5M or R I already have a 5sp and I miss my 98 V70R! Link to comment Share on other sites More sharing options...
Piston Slapper Posted March 10, 2012 Report Share Posted March 10, 2012 M58. Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted March 10, 2012 Author Report Share Posted March 10, 2012 M58. Show me the way Sir. Link to comment Share on other sites More sharing options...
850wagonT5 Posted March 10, 2012 Report Share Posted March 10, 2012 $2k on a basic engine refresh/rebuild? If you spend that much, you're doing it wrong (or dropping a car off at a shop and having them do it, then it might cost that much). If you have a decent budget, and you're bothering to take it apart...do something special or worth while. Be one of the few to get a decently ported head (not just gasket matched...I'm talking O/S valves, narrow stems, bowl and port work). Then get some CAT cams. You'll be making 30+whp more than cars with the same bolt on parts as you. I'd do that first, see how much money was left over, and decide on the rest after that. You'd likely have over $1G left. But that would be money well spent. Link to comment Share on other sites More sharing options...
andyb5 Posted March 10, 2012 Report Share Posted March 10, 2012 M58. An M66 is way easier to find, given that no US market cars came with an M58 Link to comment Share on other sites More sharing options...
mdlimy Posted March 10, 2012 Report Share Posted March 10, 2012 buy a good known low milage RN motor from a dismantler like lkq or keystone or any shop like that, you will spend 400-800 on a motor depending on milage, i got my 02 t5 motor with 120k for 500 bucks. Dont open the motor, do the normal stage zero shit like the pcv system and drop the pan and clean the pick up tube and replace the orings, now pick up a decent 50 trim turbo for about 500 bucks, bolt it on with an adapter flange, have some oil and coolant lines made and drop it all in. Hit up lucky for an ard tune and call it good. If your smart you could do that all for 2k, i know i could. of course i forgot the basic shit you also need like a fmic and an exhaust, thats all easy stuff tho. An RN motor bone stock is good for some decent numbers, 350+whp which is more than enough to have some fun. Everytime i see a thread like this it makes me want to pickup the first 850 i find with a blown motor and swap a bone stock rn motor into it with a 57trim and go dyno 350whp in a car that im into 3k :lol one of these days. Link to comment Share on other sites More sharing options...
