ohsleeper Posted March 22, 2012 Report Share Posted March 22, 2012 Can someone help me with what the procedure is to do this? Is it more involved than just putting the mechanical tensioner where the old pulley goes? I know the hydro one is better but I ordered the wrong one and I don't mind having to replace the tensioner every belt change. Link to comment Share on other sites More sharing options...
InitialDriveGTR Posted March 22, 2012 Report Share Posted March 22, 2012 If you ordered the hydraulic belt, you need a different belt. Check this thread out: PS I would either return the mechanical tensioner, or sell it, and then get the hydraulic setup Link to comment Share on other sites More sharing options...
ohsleeper Posted March 22, 2012 Author Report Share Posted March 22, 2012 Yeah it's mostly a timing thing. (ha no pun intended) the belt and other goodies are already off. Not really sure what hole it's talking about without looking. If its not the same spot for the pulley I wonder why it would be there before the mechanical one was in use. Link to comment Share on other sites More sharing options...
InitialDriveGTR Posted March 22, 2012 Report Share Posted March 22, 2012 It's where the top bolt of the hydraulic tensioner usually goes iirc. My guess is when they converted to the mechanical tensioner, they designed the tensioner to fit onto existing hydraulic tensioner blocks Link to comment Share on other sites More sharing options...
ohsleeper Posted March 22, 2012 Author Report Share Posted March 22, 2012 Oh ok that makes sense. Hmmm... Link to comment Share on other sites More sharing options...
Yellow95 Posted March 22, 2012 Report Share Posted March 22, 2012 Did the hydraulic tensioner fail or is it leaking? If not then you are good to reuse. I dont think I have ever heard of a oem hydraulic tensioner failing. Link to comment Share on other sites More sharing options...
ohsleeper Posted March 22, 2012 Author Report Share Posted March 22, 2012 People usually replace at least the tensioner pulley though correct? And If I were to leave it I would have to get a different belt. Link to comment Share on other sites More sharing options...
ohsleeper Posted March 22, 2012 Author Report Share Posted March 22, 2012 Can someone confirm that the mechanical tensioner goes in the top hole for the hydraulic unit? Link to comment Share on other sites More sharing options...
Keaton85 Posted March 22, 2012 Report Share Posted March 22, 2012 If you are converting to mechanical you need to drill and tap a hole. I always thought it was already predrilled but found that out the hard way when converting my T5M. It's possible but I would just keep the hydro setup due to this fact. So at a minimum replace the tensioner, belt and idler. Link to comment Share on other sites More sharing options...
ohsleeper Posted March 22, 2012 Author Report Share Posted March 22, 2012 Perfect that's what I needed to hear. I'll get the other set up ordered. Thanks. Link to comment Share on other sites More sharing options...
