pedro fandango Posted March 30, 2012 Report Share Posted March 30, 2012 i'm inevitably going to have to change the con-rods on my 1994 854 T-5, but the question is do i simply replace the 139's with aftermarket one's, or change to the 147mm later one's (again forged) while at it basically what are the advantages to the longer rods? I'm going for a 2002- crank while i'm at it if that makes any difference many thanks Link to comment Share on other sites More sharing options...
Rsterns Posted March 30, 2012 Report Share Posted March 30, 2012 I'm not completely positive, but it's my understanding that the longer rods are for the newer white blocks. Also a different piston to coinside. I'd do some really good homework before I started swapping stuff around. Remember these are interference motors and you don't want more interference than designed if you like keeping your valves intacked. Link to comment Share on other sites More sharing options...
pedro fandango Posted March 30, 2012 Author Report Share Posted March 30, 2012 I'm not completely positive, but it's my understanding that the longer rods are for the newer white blocks. Also a different piston to coinside. I'd do some really good homework before I started swapping stuff around. Remember these are interference motors and you don't want more interference than designed if you like keeping your valves intacked. yeh sorry, the 147mm rods have a shorter piston which obviously i'd swop/use. Just wondered what advantages there are to using the newer combination & if it was worth swopping from my older set-up to the new while changing the rods anyway Link to comment Share on other sites More sharing options...
Rsterns Posted March 30, 2012 Report Share Posted March 30, 2012 yeh sorry, the 147mm rods have a shorter piston which obviously i'd swop/use. Just wondered what advantages there are to using the newer combination & if it was worth swopping from my older set-up to the new while changing the rods anyway It's my understanding that the longer rods are a bit less prone to bending and the combination of rod and piston are marginally lighter. If your replaceing, H beams are the way to to remove any doubt of bending due to additonal mods. Link to comment Share on other sites More sharing options...
