Brad850 Posted April 15, 2012 Report Share Posted April 15, 2012 Found a few good threads on this but I just wanted to make sure. Had to replace the oil pump seals and I screwed up the timing. Here is a picture of my cams with the crank in the correct position. They are obviously off timing. My question is does it matter what direction i rotate them in or can I just simply line them up? Also as long as all three marks are lined up that's all I need to worry about correct? Thanks guys. Link to comment Share on other sites More sharing options...
Keaton85 Posted April 15, 2012 Report Share Posted April 15, 2012 As long as the crank is on the correct timing mark then yeah, move them around do whatever you want with them. Just make sure they are on the marks when the belt is installed. Doesn't matter how you do that as long as the crank is on the mark when you do so.Move them both counter clockwise to the mark and your good. Link to comment Share on other sites More sharing options...
Brad850 Posted April 15, 2012 Author Report Share Posted April 15, 2012 Knew you'd come through for me. Thanks! Link to comment Share on other sites More sharing options...
