c70dude87 Posted April 20, 2012 Report Share Posted April 20, 2012 Im running a single 12inch sub with a cap on a c70 with/ dolby. i upgraded the alternator to 120 amp, brand new interstate battery and brand positive cable wire thats ran through the fuse box. All of my lights except my HID's are having this "wavy dimming" ,even when the stereo is off. Could it be a bad ground or something???? Link to comment Share on other sites More sharing options...
okoye Posted April 20, 2012 Report Share Posted April 20, 2012 you definitely would need to check your cables. you wouldnt want a fire. Link to comment Share on other sites More sharing options...
MattyXXL Posted April 20, 2012 Report Share Posted April 20, 2012 Do the 70's have a voltage reg like the 850's? if so after checking the cables, id test the voltage reg.. thats if you have one thats like the one on the 50 Link to comment Share on other sites More sharing options...
Piston Slapper Posted April 20, 2012 Report Share Posted April 20, 2012 Do the 70's have a voltage reg like the 850's? if so after checking the cables, id test the voltage reg.. thats if you have one Pretty much all cars do... Link to comment Share on other sites More sharing options...
MattyXXL Posted April 20, 2012 Report Share Posted April 20, 2012 Pretty much all cars do... Thank you captain obvious... I was referring to the type of regulator... Ive replaced mine 3 times in 16 years Link to comment Share on other sites More sharing options...
JVC Posted April 21, 2012 Report Share Posted April 21, 2012 What OHM are you running your sub at with how much Wattage? I ran mine at 1 ohm and lights dimmed, swapped out for a different woofer at 4 ohms and it doesn't dim anymore because the wattage is less for 4 ohm. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted April 21, 2012 Report Share Posted April 21, 2012 Im running a single 12inch sub with a cap on a c70 with/ dolby. i upgraded the alternator to 120 amp, brand new interstate battery and brand positive cable wire thats ran through the fuse box. All of my lights except my HID's are having this "wavy dimming" ,even when the stereo is off. Could it be a bad ground or something???? Probably not the sub unless its dimming with each low note. And you have a capacitor so that stores power for when you need it..look for loose battery and alternator wires. What brand alternator (is it a reman) HIDs are not dimming because the ballast is converting power.. Link to comment Share on other sites More sharing options...
Paultakular Posted April 22, 2012 Report Share Posted April 22, 2012 Capacitors really aren't useful at all.. the only benefit to them is a flashing lights a voltage reading. If you really wanted to make sure your amp was getting plenty of power wire in a second battery Link to comment Share on other sites More sharing options...
c70dude87 Posted April 22, 2012 Author Report Share Posted April 22, 2012 Probably not the sub unless its dimming with each low note. And you have a capacitor so that stores power for when you need it..look for loose battery and alternator wires. What brand alternator (is it a reman) HIDs are not dimming because the ballast is converting power.. its a bosch alternator...i might look into running a seperate battery. ill check on that voltage regulator too. thanks guys Link to comment Share on other sites More sharing options...
mune237 Posted April 23, 2012 Report Share Posted April 23, 2012 Besides the sub, is the rest of the system stock for the C70? No added amps? Link to comment Share on other sites More sharing options...
95-850 wagon Posted May 1, 2012 Report Share Posted May 1, 2012 check this out... Performing The "big 3" Upgrade On Your Volvo 850...under audio and video Link to comment Share on other sites More sharing options...
BEJinFBK Posted May 1, 2012 Report Share Posted May 1, 2012 Im running a single 12inch sub with a cap on a c70 with/ dolby. i upgraded the alternator to 120 amp, brand new interstate battery and brand positive cable wire thats ran through the fuse box. All of my lights except my HID's are having this "wavy dimming" ,even when the stereo is off. Could it be a bad ground or something???? If the dimming is pulsed and regular, NOT dropping with bass hits, a big three upgrade probably won't make any difference. It may be a poor connection or a bad cable tripping up the regulator, but I'd start with the alternator and/or regulator. OP - Did you resolve this? Link to comment Share on other sites More sharing options...
