ProAv Posted April 21, 2012 Report Share Posted April 21, 2012 While doing an oil pan repair that may get documented elsewhere in this forum, I noticed this rectangular part with rubber lines running to it bolted to the back of the pan. What in the world is it? See the photo below. Disregard the aviation spark plug in the oil pan for now.. Link to comment Share on other sites More sharing options...
831t5r Posted April 21, 2012 Report Share Posted April 21, 2012 It is a oil cooler Link to comment Share on other sites More sharing options...
burnout8488 Posted April 21, 2012 Report Share Posted April 21, 2012 It's an oil cooler. Oil flows through it as well as coolant. The oil can get hotter than the 170-190º the engine is designed to run at, so the coolant effectively removes heat from the oil inside it. Never saw one like it before I had my Volvo either! Link to comment Share on other sites More sharing options...
ProAv Posted April 24, 2012 Author Report Share Posted April 24, 2012 OK, thanks. That makes sense now. Link to comment Share on other sites More sharing options...
VolvoGuy500 Posted May 4, 2012 Report Share Posted May 4, 2012 As others said - it's an oil cooler. IIRC all 03+ turbo cars had these. Prior to this, oil was sent to a section of the radiator. Link to comment Share on other sites More sharing options...
greekone Posted May 4, 2012 Report Share Posted May 4, 2012 As others said - it's an oil cooler. IIRC all 03+ turbo cars had these. Prior to this, oil was sent to a section of the radiator. '99+ Link to comment Share on other sites More sharing options...
