marsman Posted April 29, 2012 Report Share Posted April 29, 2012 Over the last several months I have noticed a squeel at speed (02 S60 2.4T with 196,000mls) - over 25 mph and it sounds like it is coming from the right front passenger side. I have semi metalic brake pads and when I apply the brakes it squeels too. This sound is similar to that sound. I installed the brake pads and did not change the rotors at the time - about 1.5 years ago. Also, my steering rack needs to be replaced, could this be making the noise? Or would it possibly be the bearing hub assembly? I read that a failing bearing hub makes a low roaring sound when going bad though, not sure. Thank you! Link to comment Share on other sites More sharing options...
survolvo Posted April 29, 2012 Report Share Posted April 29, 2012 Might be a caliper sticking. You would notice a wheel bearing making more noise when taking a curve. I don't think that rack would make the noise, turn the wheel while not driving and see if you hear it at all. Link to comment Share on other sites More sharing options...
marsman Posted April 30, 2012 Author Report Share Posted April 30, 2012 Will do, thanks! Link to comment Share on other sites More sharing options...
