(_8*(l)Homer Posted June 13, 2012 Report Share Posted June 13, 2012 So, I replaced my BCS with an ACDELCO one. Afterwards, the car ran great, better than it ever has before. Turbo response was great. This was a couple weeks ago, WOT was fine. Now, when I go WOT the car takes off like it should, then it feels like the transmission kinda shifts the wrong way and the RPMs pin at 6k. The car goes from a quick accelerating state to deceleration, where it feels like i am using the brakes. Note: I replaced a hose that goes from the BCM to the clean air pipe with a 1.0 bar one from autozone. Could this be a cause? What about the bov? Is that something that i should look at? Link to comment Share on other sites More sharing options...
(_8*(l)Homer Posted June 13, 2012 Author Report Share Posted June 13, 2012 oops...meant to post in maintenance. Link to comment Share on other sites More sharing options...
Gideon35T Posted June 15, 2012 Report Share Posted June 15, 2012 Could be that you're hitting boost cut but maybe all your renewed performance made for a new issue. Link to comment Share on other sites More sharing options...
WayAway Posted June 15, 2012 Report Share Posted June 15, 2012 I dont think m4.4 has a fuel cut like m4.3 Link to comment Share on other sites More sharing options...
(_8*(l)Homer Posted June 16, 2012 Author Report Share Posted June 16, 2012 The car definitely does not perform as well as it did when I first added the new BCS a month ago. I could go 0 - 60 in probably 7 seconds and the car SCREAMED on the highway, could go 60 - 100 in about 6 seconds (or so it seemed). Now it really feels like all sorts of wrongness when I get on it. I am going to replace vac hoses and check the intercooler couplings for any leaks as suggested in the maint forum. Link to comment Share on other sites More sharing options...
(_8*(l)Homer Posted June 17, 2012 Author Report Share Posted June 17, 2012 So, I found my vac leaks. There were 3 of them. Two at the BCS, one on the clean air pipe down at the bottom. I used zip ties to tighten up the hoses, but found that that is actually what caused the leaks. So, 5 hours later my car is running great and has no other vac leaks that I could find :) Link to comment Share on other sites More sharing options...
s_moneh Posted June 18, 2012 Report Share Posted June 18, 2012 I think the strange thing happening at WOT is unaturally aspirated air going into the engine. It would put you in your seat thats for sure Link to comment Share on other sites More sharing options...
