hgray14 Posted July 13, 2012 Report Share Posted July 13, 2012 Over the past year I have had trouble with the exterior door trim on my two back doors. After sitting in the sun and warming up, if I open the back doors the trim gets caught and instead of sliding inside the front door, it goes the outside, which then bends it badly. Is there a solution to stop this from happening? It bent so badly on both sides that I removed both rear door trim pieces and am now trying to decide what to do. If I can get them bent back properly, how do I keep them from flare out again? Am I better off getting new trim pieces? I assume there are some heavy duty adhesives out there but I would prefer not do that because I want to be able to remove the trim if need be (like to re-dye it black.) Any suggestions would be greatly appreciated - I am tired of driving around with those two pieces missing. Link to comment Share on other sites More sharing options...
Mesoam Posted July 13, 2012 Report Share Posted July 13, 2012 has your car been hit? this only happened to mine after it suffered the death blow... i would suggest taking a heat gun to them and seeing if you can massage it down, if not pickup some used pieces, there have got to be a ton of them out there Link to comment Share on other sites More sharing options...
hgray14 Posted July 13, 2012 Author Report Share Posted July 13, 2012 That sounds like a good plan. I guess I am concerned that if it happened to both of mine (no, no accidents) that it might simply be an age thing and that I would run into similar problems with others. But if this is fairly unique, than replacing them seems like the way to go. Link to comment Share on other sites More sharing options...
