thewhiteguy1 Posted July 13, 2012 Report Share Posted July 13, 2012 how in the flying fuck does this even happen. discuss. Link to comment Share on other sites More sharing options...
RZT5 Posted July 13, 2012 Report Share Posted July 13, 2012 OBX I assume? Poor design causing too much stress on the weld... Crappy welds... Welding without filler wire... Hard to know for sure exactly what caused it. Sorry to see though :( Link to comment Share on other sites More sharing options...
Scania Posted July 13, 2012 Report Share Posted July 13, 2012 That is custom performance exhaust, usually you have to pay extra for that ! Not a huge deal, pull it out & weld it up. I'd go over the other welds too. Link to comment Share on other sites More sharing options...
D s50r Posted July 13, 2012 Report Share Posted July 13, 2012 Can't be a weld because it's not welded there and the edges look really jagged looks like sOmeone took a sawzall to your downpipe.. Do you have "beef" with someone? I do have a brand new downpipe if you need a replacement Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted July 14, 2012 Author Report Share Posted July 14, 2012 Can't be a weld because it's not welded there and the edges look really jagged looks like sOmeone took a sawzall to your downpipe.. Do you have "beef" with someone? I do have a brand new downpipe if you need a replacement i can't figure how someone would get down there in the first place, there is no room for a sawzall, let alone get into the engine bay. but he is right there is no weld there.... Link to comment Share on other sites More sharing options...
caanglin Posted July 14, 2012 Report Share Posted July 14, 2012 Bet it was Charlie. Link to comment Share on other sites More sharing options...
D s50r Posted July 14, 2012 Report Share Posted July 14, 2012 It looks like the cut is angled so a cut from under te car with a cordless sawzall is possible. Do you have a cat on the exhaust? Someone might have been after thatAnd got spooked by something and stopped Link to comment Share on other sites More sharing options...
survolvo Posted July 14, 2012 Report Share Posted July 14, 2012 Have you moved the car since finding this? If not, you can look and see if there are any little metal shavings around that area or the ground to tell if its been cut. Sure looks like it was cut. Aluminum had hard spots in it, so if it cracked and broke, it wouldn't be that straight. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted July 14, 2012 Author Report Share Posted July 14, 2012 It looks like the cut is angled so a cut from under te car with a cordless sawzall is possible. Do you have a cat on the exhaust? Someone might have been after that And got spooked by something and stopped Have you moved the car since finding this? If not, you can look and see if there are any little metal shavings around that area or the ground to tell if its been cut. Sure looks like it was cut. Aluminum had hard spots in it, so if it cracked and broke, it wouldn't be that straight. don't have a cat on the car. i will look for metal shavings, but I have coilovers on the car and it is pretty low. I cannot get a jack underneath without 2x4s. shitty weld fix above^ Link to comment Share on other sites More sharing options...
gilber33 Posted July 14, 2012 Report Share Posted July 14, 2012 :lol: How the fuck does that happen? That's random. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted July 14, 2012 Report Share Posted July 14, 2012 Cheap stainless from china. My OBX flex joint is leaking I think..I have to get under and see if it's cracked where it's welded to the pipe. Link to comment Share on other sites More sharing options...
D s50r Posted July 14, 2012 Report Share Posted July 14, 2012 Hmm wow that's really strange that it broke like that wow Link to comment Share on other sites More sharing options...
Dick Dastardly Posted July 14, 2012 Report Share Posted July 14, 2012 Do you have bad motor mounts? If the engine is rocking too much this will happen. Usually on a weld but these downpipes are really thin.. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted July 14, 2012 Author Report Share Posted July 14, 2012 Do you have bad motor mounts? If the engine is rocking too much this will happen. Usually on a weld but these downpipes are really thin.. matt b asked me the same thing. haven't checked the motor mounts to see if bad or not Link to comment Share on other sites More sharing options...
s_moneh Posted July 14, 2012 Report Share Posted July 14, 2012 don't have a cat on the car. i will look for metal shavings, but I have coilovers on the car and it is pretty low. I cannot get a jack underneath without 2x4s. they use air bags now they will get under the lowest of the low. no ones safe anymore! Link to comment Share on other sites More sharing options...
