mundtquist Posted July 20, 2012 Report Share Posted July 20, 2012 Hi, I have a 2000 S80 T-6 that is running rough and not developing full power. It has 200,000 miles on it and it is new to me. I bought CHEAP it from a friend of a friend who was going to donate it. Symptoms: -Runs like it is missing on one cylinder -codes for misfire on cylinder #5 and all 4 02 heaters -smooths out when I unplug the MAF I have put in new plugs and a new coil on #5 without success. I have swapped in a MAF from a good running S80 T-6 without success. My thought is that it is a bad MAF and that the bad MAF is causing the misfire and 02 codes. However, I am not sure and I hate to spend $200 unnescessarily. Your thoughts? Thanks, Steve Mundtquist Posts: 1 Joined: 10 Nov 2011, 23:25 Location: MN Model, Year: S80 2000 Link to comment Share on other sites More sharing options...
burnout8488 Posted July 21, 2012 Report Share Posted July 21, 2012 ETM. Go to a junkyard and get a throttle body with a yellow label. Don't replace anything until you know there is a known good MAF and ETM on the car. Otherwise it will nickel and dime you to death. This car is going to put you through your paces, be ready! Link to comment Share on other sites More sharing options...
atefitty Posted July 22, 2012 Report Share Posted July 22, 2012 If the throttle unit is bad you will have a code in the ecu for that. Link to comment Share on other sites More sharing options...
mundtquist Posted July 24, 2012 Author Report Share Posted July 24, 2012 Hi, The ETM is yellow stickered. I will swap coil packs to make sure it is not a bad replacement. I will then probable try a new maf. Thanks, Steve Link to comment Share on other sites More sharing options...
burnout8488 Posted July 28, 2012 Report Share Posted July 28, 2012 A yellow ETM can still have 120,000mi on it depending on when it was originally replaced. They can fail as early as 50,000mi, so yours has the potential for being very old. Don't rule it out. They don't need to set a code in order to be the culprit. MAF is a good next step however. Link to comment Share on other sites More sharing options...
