Rsterns Posted November 27, 2012 Report Share Posted November 27, 2012 Going from the experience of Rsterns 98 T5, I'd say no. He built the motor, and had a set of stock rods shot peened and cryo treated, but still bent a rod after a detonation at 18psi (on an IPD stage 3 tune) from an 18T with full bolt-on supporting mods. He then rebuilt the motor with forged rods and hasn't had any issues since. Your statement is true, replaced the rods with LGS, but I still cryo treated them as well as the pins and pistons and rings. Close to 100K on this build without issues and I by no means baby this car. I use what it has daily. Link to comment Share on other sites More sharing options...
D s50r Posted November 27, 2012 Report Share Posted November 27, 2012 Yea I def should have measured first damn volvo!! Should I find a different motor for the rods I have? Will the ones I have fit the s60r engine? Link to comment Share on other sites More sharing options...
Rsterns Posted November 27, 2012 Report Share Posted November 27, 2012 Curious, by chance have you been able to perform a Rockwell Hardness test on the three sets of Rods? should lend insights to the forging process. Also as a data point, I had my LGs Rods weighed, and they were also with in 1 gram of each other across the set of 5. Link to comment Share on other sites More sharing options...
boxpin Posted November 27, 2012 Report Share Posted November 27, 2012 My china rods are rockin' at 1200 miles so far. Wrist pins fit perfect and the engine sings. Link to comment Share on other sites More sharing options...
D s50r Posted November 27, 2012 Report Share Posted November 27, 2012 What engine do you have boxpin Link to comment Share on other sites More sharing options...
boxpin Posted November 27, 2012 Report Share Posted November 27, 2012 B5234T5 Link to comment Share on other sites More sharing options...
andyb5 Posted November 27, 2012 Report Share Posted November 27, 2012 Yea I def should have measured first damn volvo!! Should I find a different motor for the rods I have? Will the ones I have fit the s60r engine? Too lazy to text you 147mm rods are the "strongest" (best rod/stroke ratio) so if it isn't too much to get a set of 147mm rods, that's the best way to go. Link to comment Share on other sites More sharing options...
D s50r Posted November 27, 2012 Report Share Posted November 27, 2012 What hp numbers are u at?Haha finnnneeee I'll get the right rods for this motorHaha finnnneeee I'll get the right rods for this motor Link to comment Share on other sites More sharing options...
Stork Posted December 27, 2012 Report Share Posted December 27, 2012 I wasn't actice here so far just folowed the interesting posts which are very useful. Have now all my components together witout the rods which I like to have for confidence. Now I ordered fom Alamo a set connectinhg rods and got the 5 pieces. 3 of them where marked with a 800 number and the other 2 with a 400 number code. I put them an a scale and found a weight difference of 10 gram between the two series. Has anyone made the same experience? The difference is there for sure. Link to comment Share on other sites More sharing options...
marlint5 Posted January 27, 2013 Report Share Posted January 27, 2013 Any other options/companies for me to get 147mm H beam rod other than RSI - no issues with RSI, i just need options, i have CX racing rod in my possessions - 139.5mm for N engine, im diverting my built to RN engine now. advice and recommendations is highly appreciated. Link to comment Share on other sites More sharing options...
prasamin Posted January 27, 2013 Report Share Posted January 27, 2013 Any other options/companies for me to get 147mm H beam rod other than RSI - no issues with RSI, i just need options, i have CX racing rod in my possessions - 139.5mm for N engine, im diverting my built to RN engine now. advice and recommendations is highly appreciated. why not trade with D s50r? he has the rods you need, and you have the rods he needs...... Link to comment Share on other sites More sharing options...
D s50r Posted January 27, 2013 Report Share Posted January 27, 2013 Returned the 147mm rods I only have the 143 rods for the r engine now sry Link to comment Share on other sites More sharing options...
