blkaplan Posted July 26, 2012 Report Share Posted July 26, 2012 I'd be curious to see how those shocks stand up over time, with no weather protection on the shafts, all the winter salt and road grime would wear them out PDQ... so far i have about 4 years of driving all seasons on a couple different cars without dust boots on the dampers and haven't had any problems. Its easy enough to add a dust boot though and definitely not a bad idea. When you mount them inverted alot of the debris falls off. Link to comment Share on other sites More sharing options...
burnout8488 Posted July 31, 2012 Report Share Posted July 31, 2012 S70 AWD springs are stiffer and longer than V70 AWD springs, and will provide a nice drop on a V70/850 AWD when not using nivos. Not saggy, but not high. What happens if you used a normal XC spring without a nivo? Wouldn't that give it a decent height as well, or would it be saggy? Link to comment Share on other sites More sharing options...
Dan A Posted July 31, 2012 Report Share Posted July 31, 2012 I did this two years ago. The ride sucked. Try going over a speed bump. The rear will shoot up and slam back down. Also tried multiple spring rates in place of the stock ones. Link to comment Share on other sites More sharing options...
NEU Posted July 31, 2012 Report Share Posted July 31, 2012 What happens if you used a normal XC spring without a nivo? Wouldn't that give it a decent height as well, or would it be saggy? XC springs would be the same spring rate as he's currently springs, soft. They use Nivos too, only difference is the spring and nivomat is taller. And since the rate is the same it's still going to sag. He needs to replace the spring all with something stiffer, period! No way around it... Link to comment Share on other sites More sharing options...
Matt01 Posted August 1, 2012 Author Report Share Posted August 1, 2012 I did this two years ago. The ride sucked. Try going over a speed bump. The rear will shoot up and slam back down. Also tried multiple spring rates in place of the stock ones. honestly the ride is really not bad with the stock springs, much better than the springs you sold me... burnout, i own s70 AWD springs and I did a writeup about them.edit: buy you, I mean someone from this board.. Link to comment Share on other sites More sharing options...
burnout8488 Posted August 1, 2012 Report Share Posted August 1, 2012 Those are definitely the ones off my car If you ever want to get rid of them I'd actually consider buying them back so I can do a nivo-delete myself! Would love to throw some konis in the back of my car using this method. Link to comment Share on other sites More sharing options...
Matt01 Posted August 1, 2012 Author Report Share Posted August 1, 2012 im also probably going to be selling the first set of brackets I made pretty soon. (The ones used for the writeup) I m making a new set. Link to comment Share on other sites More sharing options...
