midessa7 Posted July 31, 2012 Report Share Posted July 31, 2012 So it starts in the morning and I'll get to work and shut her down then I'll try to start it back up and it wont start. Then after about 2hrs it starts right up again. midessa7 Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 31, 2012 Report Share Posted July 31, 2012 The engine cranks but does not start? You smell fuel when this occurs? Link to comment Share on other sites More sharing options...
midessa7 Posted July 31, 2012 Author Report Share Posted July 31, 2012 Yes, almost like it's dumping to much fuel and it stinks like, I want to say it's to rich Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 31, 2012 Report Share Posted July 31, 2012 Check engine light on? You may want to crank it to replicate the fuel smell and then a have a look around the engine bay to see if you have any external fuel leaks. If not it would be wise to to pull the injector rail after turning the car off and placing a piece of carboard under it. Any stains on the cardboard will lead you to a leaking fuel injector. There should be absolutely no fuel coming from the injectors with the engine off. Link to comment Share on other sites More sharing options...
