BlackBrick Posted August 22, 2012 Report Share Posted August 22, 2012 wow, you did all of this in 3 days for your daughter?! She's one lucky girl! Link to comment Share on other sites More sharing options...
boxpin Posted August 23, 2012 Author Report Share Posted August 23, 2012 nice work. it was my understanding its supposed to be much easier to pull the trans out along w/ the engine but you didnt seem to have much trouble leaving the trans alone ... comments/observations? I consulted with Hussein but he was out of town so I had to get started. I have pulled out the top many times but only once out the bottom. I personally found the bottom harder. Its tough in the driveway. This is for the motor though, for a clutch I would do it out the bottom. If I had to do it again I would pull the turbo first then everything that was hard to get to was accessible. I did have to move the transfer case out because there is one bolt that does not clear unless its out.Oh!!! there is a big difference in the blocks. I should mention this. The AWD block has a machined section below the turbo where the transfer case sits. A standard block hits the transfer case. I had to trim a section of the block off to get it to clear. I should post a picture, its worth mentioning for others that try this. wow, you did all of this in 3 days for your daughter?! She's one lucky girl! Love my kids Link to comment Share on other sites More sharing options...
antman Posted August 24, 2012 Report Share Posted August 24, 2012 Thanks for this post i have the same car year and color for my daughter sadly hers got hit in the front end the engine is still good so were going to swap it with her parts car that had a bad engine this post pretty much answerd any questions i had Thank you . Link to comment Share on other sites More sharing options...
boxpin Posted March 6, 2013 Author Report Share Posted March 6, 2013 Here is the picture of the side of the block with the machined section out of it. This section allows for transfer case clearance. A sawsall made quick work of the new block. Link to comment Share on other sites More sharing options...
Keaton85 Posted March 6, 2013 Report Share Posted March 6, 2013 I just did my first pull with leaving the tranny in the vehicle. SO much faster, saved me hours!!! Can only be done on an automatic though. Anyway, great work!! I've had two of that color at the same time. One my wife's and one mine, we looked retarded with the identical cars. Link to comment Share on other sites More sharing options...
