vivalavolvo Posted August 31, 2012 Report Share Posted August 31, 2012 Hello, I installed a cooler for my auto box, but i need to install a bypass thermostat before it gets to cool out (below 45f and its unhappy). I'm not sure wich way the fluid comes out of the trans. Is it from the bottom port into the top where the valve body cover is? Thanks!1995 T5 Link to comment Share on other sites More sharing options...
thesameguy Posted August 31, 2012 Report Share Posted August 31, 2012 I believe it's the top port which is out and the bottom is in, but if you search the board for DIY transmission flush, you will get the answer for certain. Link to comment Share on other sites More sharing options...
laird Posted September 1, 2012 Report Share Posted September 1, 2012 I believe it's the top port which is out and the bottom is in, but if you search the board for DIY transmission flush, you will get the answer for certain. Correct. Link to comment Share on other sites More sharing options...
vivalavolvo Posted September 1, 2012 Author Report Share Posted September 1, 2012 Thanks! Link to comment Share on other sites More sharing options...
