850T5M Posted September 11, 2012 Report Share Posted September 11, 2012 So my car started running low on prestone recently and I'm tryring to figure out if its the head gasket or the turbo? Basically every 3-4 weeks I get the little light on in my dash saying low coolant, mostly when I accelerate (Fluid moves in the tank). When I start the car, there is 0 smoke that comes out of the tailpipe. If I give it just a bit of gas, its fine as well. When I boost the car, probably over like 5psi, I can see a cloud behind me, not really sure what color, but theres a cloud lol Does this usually mean the turbo seals are gone? or could it still be the HG? Link to comment Share on other sites More sharing options...
s_moneh Posted September 11, 2012 Report Share Posted September 11, 2012 i just did research on his i was having the same issue. still don't know if i've figured it out or not. but theres really no way for coolant to go missing inside the turbo unless the pipes have come off or somthing. you could have a hg issue Link to comment Share on other sites More sharing options...
Burn-E Posted September 11, 2012 Report Share Posted September 11, 2012 Have you stopped to consider it might be leaking under your floor inside the car due to a failing heater core? The other place to look is in the plastic expansion tank or the hoses - often you get a crack underneath and then it leak only when the car is under compression / running. Which means you don't get any drips under the car when it's sitting. Link to comment Share on other sites More sharing options...
850T5M Posted September 11, 2012 Author Report Share Posted September 11, 2012 So the turbo can't burn coolant? So the cloud is probably oil lol? Link to comment Share on other sites More sharing options...
Burn-E Posted September 11, 2012 Report Share Posted September 11, 2012 Not the turbo can't burn coolant but your engine can if you have a warped HG. Link to comment Share on other sites More sharing options...
s_moneh Posted September 12, 2012 Report Share Posted September 12, 2012 nope the coolant passages and oil passages have no way of touching, unless you have an internal crack in the casting. but chance of that r slim to none. Link to comment Share on other sites More sharing options...
850T5M Posted September 12, 2012 Author Report Share Posted September 12, 2012 Alright so I'll look for leaks before assuming it's the head gasket :/ Link to comment Share on other sites More sharing options...
Rsterns Posted September 12, 2012 Report Share Posted September 12, 2012 When I had a simular issue, it turned out to be a VERY SMALL pin hole leak in that short little hose that connects the hard line that runs along the back of the motor passenger side. Link to comment Share on other sites More sharing options...
boxpin Posted September 14, 2012 Report Share Posted September 14, 2012 I have this too, takes about three weeks then the light starts coming on. Thought it was the heater core since I could smell it when I turned on the heater. Maybe a small pin hole that evaporated. I recently (two weeks ago) replaced the heater core with fingers crossed. Sadly this morning the light came on again. I have not been able to find any leaks anywhere. I did replace the head gasket on this car about 7 months ago. Nothing hits the ground or is inside the cabin. Its got to be going somewhere. Link to comment Share on other sites More sharing options...
CBoosT5 Posted September 14, 2012 Report Share Posted September 14, 2012 To all with this problem. Try doing a coolant pressure test. Then a compression test. One of these chances are will pin point your problem almost immediately. Link to comment Share on other sites More sharing options...
James A Sousa Posted September 16, 2012 Report Share Posted September 16, 2012 You might shine a flashlight into each cylinder if one is clean, there is your problem. Link to comment Share on other sites More sharing options...
