Tech Posted October 13, 2012 Report Share Posted October 13, 2012 You can also use Anit-seize when pressing the dog bones into the power flex bushings. I have been using that for 4 years now when doing urethane bushings on P2 cars. Link to comment Share on other sites More sharing options...
Keaton85 Posted October 13, 2012 Author Report Share Posted October 13, 2012 That is what I was going to use but I called the company and they stated that was not a good idea. Link to comment Share on other sites More sharing options...
Tech Posted October 14, 2012 Report Share Posted October 14, 2012 That is weird but I guess to make sure for warranty issues use what they are sending. Link to comment Share on other sites More sharing options...
Keaton85 Posted October 17, 2012 Author Report Share Posted October 17, 2012 Update: Yup, ended up using anti-seize since the packet they sent is hardly enough to do one let alone enough to lube it up for insertion! The XC bushings are a must though, they are a much better bushing as they don't get stressed as much when the control arm is extended all the way down like the FWD version does. As for the powerflex bushings, these are a must have. It makes the whole front suspension completely solid like the 850/X70s. A tip for installing, due to the new bushings, you can't get the control arm down enough to insert the ball joint threads. So if you remove the ball joint from the hub with the two bolts then insert the ball joint into the control arm first and into the hub second it works a lot better. Ive never had this issue other then with the XC and powerflex bushings combined... Link to comment Share on other sites More sharing options...
Member Posted October 22, 2012 Report Share Posted October 22, 2012 I'm looking to replace FCABs in my '03 V70. Since I'm going Eibach/Koni Yellow I want stiffer FCABs. The one worry with Powerflex is how easy to press on existing control arms? We'd have a hard time at the shop doing rubber bushings but maybe Powerflex is easier? Denton Link to comment Share on other sites More sharing options...
Keaton85 Posted October 22, 2012 Author Report Share Posted October 22, 2012 FCAB? Front Control Arm Bushings? haha seriously! The front (horizontal) bushings are really easy to install (powerflex). You just have to make sure that you leave the original metal sleeve in place or you will have to buy another set just for the metal sleeve. The rear (vertical) bushings are the same press in bushings, but I used XC bushings instead of the FWD. The XC bushing is a lot better! I can't believe the original is still even used. Link to comment Share on other sites More sharing options...
