hgray14 Posted September 24, 2012 Report Share Posted September 24, 2012 I pulled up a "lock/unlock" switch from a 1996 Volvo Turbo hoping to put it into my 1995 850 Turbo. When I pulled the filler on the dash, this plug end was attached to the back side of the filler. It does not fit the switch I pulled from the '96 turbo. Does anyone know what switch this is supposed to plug into? Link to comment Share on other sites More sharing options...
boxpin Posted September 24, 2012 Report Share Posted September 24, 2012 Thats your fog light plug Link to comment Share on other sites More sharing options...
hgray14 Posted September 24, 2012 Author Report Share Posted September 24, 2012 Ah...thanks. Do you know if there is wiring in place for the locks? If not I am assuming it is a pretty hard thing to do myself and I should have taken the wires from the junked 1996 that I got the switch from in order to make things a little easier. Houston Link to comment Share on other sites More sharing options...
crazykn Posted September 24, 2012 Report Share Posted September 24, 2012 There is no direct wiring connector for the door locks. Typically to wire up this switch you will probably have to go into the large wiring bundles under the dash and start splicing and and tapping. I don't specifically know which wires to tap though. I wanted to do the same thing when I had my 95 850, but was too intimidated looking under the dash wiring. Link to comment Share on other sites More sharing options...
