vivalavolvo Posted October 23, 2012 Report Share Posted October 23, 2012 When i first got the car it came with Tethy wheels and they weren't totaly round. So on the highway i had some bad vibrations. Fast forward to now, I have 4 new wheels, tires, koni str.t shocks and sturts, kilen sport springs, bushings, mounts, and probably more then i am remembering as well as a fresh alignment. I still have a vibration at around 65-70 MPH. Any idears?95 850 T5 Link to comment Share on other sites More sharing options...
vivalavolvo Posted October 23, 2012 Author Report Share Posted October 23, 2012 Some how the W and A ran away from the title. Supposted to read Highway Link to comment Share on other sites More sharing options...
5cyl Posted October 23, 2012 Report Share Posted October 23, 2012 axle maybe? Link to comment Share on other sites More sharing options...
ErikS Posted October 23, 2012 Report Share Posted October 23, 2012 Are the new wheels a stock Volvo 850 wheel or aftermarket? Might just need some hub centering rings. Link to comment Share on other sites More sharing options...
andyb5 Posted October 23, 2012 Report Share Posted October 23, 2012 Were the new wheels+tires road force balanced? Link to comment Share on other sites More sharing options...
vivalavolvo Posted October 23, 2012 Author Report Share Posted October 23, 2012 Are the new wheels a stock Volvo 850 wheel or aftermarket? Might just need some hub centering rings. After market, and came with centering rings that fit quite snugly... but i did leave 5mm spacers in the back that i bough from autozone. Maybe i should nix them? I had them because my old tires were to wide and i never bothered to try without. Were the new wheels+tires road force balanced? I balanced them for a second time right when i put the new suspention on. What is this road force you speak of? axle maybe? I wouldnt shoot that down, but when i replaced the trans they looked/felt solid. Link to comment Share on other sites More sharing options...
ErikS Posted October 23, 2012 Report Share Posted October 23, 2012 Take the spaces out first, and see if that solves the problem, then go from there. Link to comment Share on other sites More sharing options...
5cyl Posted October 23, 2012 Report Share Posted October 23, 2012 yea if they are cheap autozone spacers that can easily cause vibrations. road force is a fancy kinda balancing that applies a load to the tire while balancing. in my experience it is def better, but even with traditional balancing the vibrations are small. nothing that would cause annoyance. I only say axle because i recently had to replace mine (broke the driver side one) and the reman from napa vibes a bit under hard acceleration and high speed. Link to comment Share on other sites More sharing options...
trs80 Posted October 23, 2012 Report Share Posted October 23, 2012 Check the wheel bearing, ball joint and tie rod for each side. Link to comment Share on other sites More sharing options...
vivalavolvo Posted November 14, 2012 Author Report Share Posted November 14, 2012 Took the spacers off today. That was the issue. Thanks! Link to comment Share on other sites More sharing options...
5cyl Posted November 14, 2012 Report Share Posted November 14, 2012 awesome. good to hear you got it fixed. Link to comment Share on other sites More sharing options...
