boxpin Posted October 24, 2012 Report Share Posted October 24, 2012 I have a question about the ARD TCV. I thought other might benefit from the answer so I am posting here. 1. Does it matter what angle/direction its mounted? 2. Is it waterproof or do I need to seal around the solenoid? 3. Is it susceptible to heat, can it be mounted near the turbo? I know it was determined that it performs best the closer it is to the turbo. I was thinking of mounting mine to the firewall bracket but that will be based on the answers. Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted October 24, 2012 Report Share Posted October 24, 2012 Off topic, but where did you get your 90° aluminum pipe with a HKS adapter? Link to comment Share on other sites More sharing options...
ARD - Lucky Posted October 24, 2012 Report Share Posted October 24, 2012 Waterproof, yes. Just don't keep it under water Heat resistant, yes. But for longevity keep it 6 inches away from the hot side of the turbo. Orientation as you like, no worries there! Let me know if you have any other questions! -Lucky Link to comment Share on other sites More sharing options...
White 850R Posted October 24, 2012 Report Share Posted October 24, 2012 Mounted mine to the wiring harness that's right next to the driver side shock tower, mine is a aem bc but same solenoid. I put some soft material between it and the hard plastic and just tied with a couple zip ties. Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted October 24, 2012 Report Share Posted October 24, 2012 mine is mounted just as shown except vertical. I have it so the line to the wastegate & compressor are a straight shot & short as possible and the recurc line I could give a funk about but that too is short. You could get some heat wrap like foil shit and make a nice pocket for it within the truss of the upper engine mount if you feel it's needed. Regardless I tend to clean mine often due to blow by & heat. Link to comment Share on other sites More sharing options...
boxpin Posted October 24, 2012 Author Report Share Posted October 24, 2012 Off topic, but where did you get your 90° aluminum pipe with a HKS adapter? Home grown Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted October 24, 2012 Report Share Posted October 24, 2012 Ohhhh shiny.... Link to comment Share on other sites More sharing options...
Auburn T5 Posted November 8, 2012 Report Share Posted November 8, 2012 I used automotive trim double sided tape (used to hold body trim/spoilers, etc onto cars) to attach mine to the fuse box. Link to comment Share on other sites More sharing options...
Kit Vexed Posted November 21, 2012 Report Share Posted November 21, 2012 orientation is quite obvious, however is the distance? i know there was a thread about it being closer, but before ARD came out with this device, i remember seeing a pic from iPd with it mounted by the battery/air intake? and this was never an issue with the 1st gen, so why is distance a factor with this new one? Link to comment Share on other sites More sharing options...
ARD - Lucky Posted November 21, 2012 Report Share Posted November 21, 2012 It's not really a factor for either, but the car responds better the shorter the distance just by virtue of less hose volume to fill :) Link to comment Share on other sites More sharing options...
Kit Vexed Posted November 21, 2012 Report Share Posted November 21, 2012 gotcha bro =) cause im planning on mounting mine to the intake shield (when it gets here lol) Link to comment Share on other sites More sharing options...
